Projects Original paint resto help on 53 Merc
Discussion in 'The Hokey Ass Message Board' started by OlSchoolCruizin, May 5, 2014.
  1. OlSchoolCruizin
    OlSchoolCruizin
    from Tampa, fl
    I just picked up a 53 Merc Monterey 4 door. Car is straight and retains its original paint with only a few specs of surface rust here and there. Unfortunately, it seem that someone at some point decided to try and protect the car by brushing on some sort of sealant. not sure what it is but its clear/matt and its flaking off in some areas. Any ideas on how to remove this so i can attempt to clean up the original paint? Any ideas would be greatly appreciated. Pics of car soon to follow.
    Lance
  2. OlSchoolCruizin
    OlSchoolCruizin
    from Tampa, fl
  3. missysdad1
    missysdad1
    No bueno attachments, OlSchool.
  4. MAD 034
    MAD 034
    from Washington
    Si --El foto es no mirar.
  5. OlSchoolCruizin
    OlSchoolCruizin
    from Tampa, fl
  6. David Totten
    David Totten
    if its flaking off either air pressure or pressure washer should take it off.
  7. leadsled
    leadsled
    that 53 is in good shape nice find
  8. missysdad1
    missysdad1
    If you want to preserve the original paint - and I really hope you do - consult a professional before you do anything. All automotive paint stores - the ones that supply body shops with their paint supplies - have access to factory reps who have the background and knowledge to diagnose paint problems. That's what they do. Take advantage of this service. Beats the heck out of screwing up the original paint by using some inappropriate chemical or technique...
  9. OlSchoolCruizin
    OlSchoolCruizin
    from Tampa, fl
    Good call on the paint shop, I do want to preserve the paint and I'm trying to exhaust all options before changing it. The pressure washer might work on the flaking areas but others are still well intact. I'm wondering if a wet sand would do the trick. It is kind of like a clear.
  10. Squablow
    Squablow
    It might be Cosmoline. In that case, you just have to wash it with hot water. Has to be hot though, cold won't do ****. If it's varnish or shellac, you'll have to figure out a solvent that will take it off without softening the old paint underneath.
    I would suggest against a wetsanding, the paint already looks thin on there and trying to wetsand through a brushed on layer of **** and then stop at already thin paint? Recipe for disaster.
  11. indyjps
    indyjps
    Agree with Squablow, test different solvents in areas that aren't visible, see what cuts into the "clear". I'm guessing polyeurthane or some sort of clear varnish, something meant for wood, so mineral spirits or acetone as a solvent. Not sure what type of paint was originally on that car and what solvents will cut into it. Verify. Be safe, spreading enough solvent to cover a body panel makes a lot of fumes, respirator and work outside, in the shade.
