Features Doing Falcons Right
Discussion in 'The Hokey Ass Message Board' started by falconizer_62, Jul 23, 2008.
  1. need louvers ?
    need louvers ?
    That would be a VERY good baseline, and gleaned in a much more scientific way than my jet specs were.:D
    gimpyshotrods likes this.
  2. stoner72
    stoner72
    from AZ
    So I did sort of buy the wrong bolts. The base was much thicker, but it is the right thread and diameter. Nuts work fine, I just wouldn't be able to replace the with the Ranger studs.
    Going to look into replacing the MC so I only have to bend brake lines once.
    Sounds like most here have used the 72(?) Maverick MC. Does it have to say disc front, drum rear? Part number? Are there clearance issues with the brace?
    Does anyone know of different methods and the a associated pros and cons? I've read about a Geo MC and also a Tracer MC.
    Also, I need to track down some wheels to replace my 13" steelies. Those too are supposed to be from a 70s Maverick, correct?
  3. gimpyshotrods
    gimpyshotrods
    As far as I know, all Mavericks had front discs. You can use Mustang and Falcon wheels, from about 65-71 (14's), Corvair, and 4-lug Maverick wheels. Datsun 240/260/280 wheels too, or aftermarket.
  4. need louvers ?
    need louvers ?
    No, some Mavs had drums. You need a MANUAL DISC/DRUM master cylinder from '74. Oh, and I don't care who wants to refute this and then try to "inform" me of what a proportioning valve does, if you are doing this with the Scarebird recommended parts you do not need one.
  5. need louvers ?
    need louvers ?
    I would personally pass on any sort of power brakes unless you have some sort of problem that would require it's use. Part of the coolness of these cars is that they are light and simple enough that they don't NEED all of the B.S. that a late model car has and destroys the quality of the drive.
  6. gimpyshotrods
    gimpyshotrods
    My Maverick memories are fuzzy.
  7. Mike51Merc
    Mike51Merc
    Here we go again.....
    Stoner72 (and anyone else doing a disc brake swap), do yourself a favor and do some independent research on proportioning valves before taking anyone's advice on a forum as gospel. Scarebird sells brackets, not systems.
    And by the way, here is a direct quote from Scarebird's web page for Falcon conversions:
    "This setup will work with the stock drum master, though we recommend you change over to a 1974 disc master* and install an adjustable proportioning valve."
  8. redzula
    redzula
    Had a little trouble coming in to work today. Car acted like it was out of gas then when you coast a little bit it works again for awhile. I limped it to a station and filled up but it only took 8 gals. It's done this a few other times and those times it only took 2-3 gals. I'm suspecting that my fuel pump isn't keeping up with my new weber 2 barrel (I.e. it can't keep the bowl full and when it's out it wants to die the coasting it fill back up a bit) I'd like to keep my mechanical pump since it's new and I don't really care for the look of an electric. Does anyone make a high volume pump for the 170. If I have to I suppose I could hide an electric and run it through the mechanical pump to keep the look, I saw someone that did that on a flathead one time. Am I looking in the wrong spot.
    About the electric pump would it be better to piggyback the mechanical and use both together or disable the mechanical so that the pressure is all electric.
  9. gimpyshotrods
    gimpyshotrods
    Did you check/set the float level?
  10. gimpyshotrods
    gimpyshotrods
    You mean here YOU go again.
    What year Falcon do you own, and where did you get your engineering degree?
    Just asking, as some might want to vet your credentials.
  11. redzula
    redzula
    Before I put it on but I haven't rea) u checked it either. I suppose that would be a cheaper place to look first.
  12. Mike51Merc
    Mike51Merc
    A '63 Falcon, as we previously discussed in this very thread. I make no claim of my own knowledge here, just my findings. I don't need an engineering degree because I rely on other's engineering degrees.
    You're the one making unsupported claims here, what about your credentials?
  13. need louvers ?
    need louvers ?
    So, Gimpy and I are making unsupported claims? Great! I guess driving my car as my only transpo for over 9000 miles in just over 7 months is COMPLETELY unsubstantiated. Nope, that didn't happen, and I crashed and died. I guess the other four I did for customers that are happily driving their cars around and stopping correctly is unsubstantiated as well. Or the similar conversion I did on my personal Maverick, or, for that matter the set I MADE for my personal (using similarly sized components) '62 Falcon back in '82 when I got it and started driving does nothing for substantiation, either.
    So you worry about MY credibility.... Where do we start. I bought my first street rod, a '35 Ford coupe at 12 in '78. With the help of my neighborhood mentors I drove it around my still very rural home of north Scottsdale at 14. I traded that for a '39 Ford coupe at 15, and went through another string of building/buying cars from then on. In '82 I landed my first job in the street rod industry at MAR FAB, and under the guidance of Don Marks, honed my fab, welding, mechanical and machining skills. I tuned and drove sports racing cars with Flint Foreign auto's racing team throughout the late eighties, and with a partner founded and worked Top Cat VW repair here in town. Back in hot rods in the early nineties I helped my friend ELpolacko start and run Industrial Chassis here in town, where one of the many things I have had my hands in was prototyping a couple of different brake kits that were later picked up by Baer Brakes here in town. For the last twenty five years I have run my own shop Hot Rod Central Louver Co., first part time to a busy corporate career, and about ten years ago went full time with it and expanded to frame and chassis builds, metal repair, hot rod plumbing, wiring, and set up and repair of cars that the more "paint shop" oriented local shops can't seem to make work right.
    I have NEVER owned a late model car, and ALWAYS rely on vintage cars I have built and drive for daily transpo. My first Falcon came to me on April, 22nd 1982 and it is still with me awaiting it's next build after serving faithfully for well over 200,000 miles.
    With a little over 35 years in this industry as a fabricator and builder, I think I might just have a handle on this braking thing, and how it all works.
    To sum it up, Some cars DO need an adjustable "prop" valve. I was taught many years ago before such things were commercially available, (anybody else old enough to remember scouring wrecking yards for the Kelsey-Hays unit on late sixties T-Birds?) to plumb and test a system first, and use an adjustable as a last resort.
    Conversely, if you can absolutely match a donor car's weight, distribution, and braking characteristics to what you are building, go ahead and use a combination valve... But, most of the time a non-adjustable won't get you where you need to be.
    As I said earlier before you accused me of putting myself, my customers and the world in general in harm's way, if YOU feel you need to put an adjustable proportioning valve into YOUR car's system go ahead and do it. I won't stop you. I have not experienced the need to do that with THIS COMBINATION of brake parts on these cars.
    Pretty freakin' simple... And, as far as I'm concerned, the last I'll say of this.
    Hollis Cranmer and gimpyshotrods like this.
  14. gimpyshotrods
    gimpyshotrods
    Massachusetts Institute of Technology, Masters Degree in Mechanical Engineering, 6th in class.
  15. Mike51Merc
    Mike51Merc
    As I said before, this is not about your personal experience, or mine for that matter. This is about making blanket statements to people that disc brake swaps into Ford Falcons don't require proportioning valves. My opinion is that is incorrect based upon the weight of information I collected and I found absolutely no information supporting your position, except for you and Gimpy's description of your personal experience.
    Minds much more knowledgeable and experienced than mine have decided to spec proportioning valves into Falcon swaps. I decided to trust their experience, with all respect to your 7 month/9000 mile driving experience. As you can see, even Scarebird says they recommend a prop valve---- and you came here and told the world that they didn't recommend one.
    The bottom line as I see it is this, unless you have one of those brake force testing machines, you really don't know whether your braking forces were properly proportioned. Your experience is what's called anecdotal, meaning it is interesting but doesn't really prove anything.
    I never accused you of anything. I simply described what might happen if the poo-poo hit the fan and you happened to be standing in its path. This is from somebody who definitely knows about that sort of thing.
  16. Mike51Merc
    Mike51Merc
    Very Impressive.
    So kindly explain to me in your professional opinion why Ford motor company and every vendor of aftermarket brake swaps that utilize proportioning valves are wrong and you are right?
  17. DAGONITWIT
    DAGONITWIT
    from NO VA
    Why don't you guys start a new thread on proportioning valves etc.
    This ain't the place for it!
  18. need louvers ?
    need louvers ?
    Agreed 100%! As I said ion my last deal, I'm done with this shit!
  19. gimpyshotrods
    gimpyshotrods
    Yup. I'm over it.
  20. Battery relocation project on my 63 2dr sedan:
    Cardboard template and 1/8" mounting plate:
    Test fit:
    Building it dirty:
    Some 1/4-20x3/4" studs n' white paint:
    From left to right, top to bottom, Cole-Hersee starter Solenoid 24046, 125 HMEG fuse for accessory/ignition circuit, 125A HMEG fuse for B+ alternator circuit, Cole-Hersee 100% duty solenoid 24213 for alternator shut down, 300A master disconnect, Group 24 battery.
    Into the trunk:
    Running cable:
    Ground point on engine block via 12.5' negative battery cable:
    Home Depot chrome drawer pull:
  21. need louvers ?
    need louvers ?
  22. Thanks Chip- I tend to get carried away with anything electrical....
    A buddy of mine tells me "if it can be done with an in-line fuse, you'll do it with a Bosch double throw relay, a circuit breaker and an in-line fuse....."
  23. mcnally351
    mcnally351
    from boston
    Very clean work! Did you have to add a high torque starter? Or does the stock started work with it in the truck?
  24. need louvers ?
    need louvers ?
    I have been accused of the same!
  25. DAGONITWIT
    DAGONITWIT
    from NO VA
    :eek: Freakin' overachiever! LOL Very nice work Al.
    Just curious, what size main cables did you use?
  26. loudbang
    Very nice work!!
  27. I'm using a dead stock starter with the starter solenoid in the trunk.
    I'm an overachiever? You haven't posted any pictures of your 63 Hardtop's suspension system lately....LOL!
    I used 1 gauge cable for the battery, 8 gauge for the ignition/accessory and alternator circuits and 10 gauge to carry the start signal to the trunk solenoid.
    I was too lazy to run a new wire from the start terminal on the ignition switch to the solenoid in the trunk so I just used the existing starter solenoid on the fender apron in the engine bay to send the start signal (via 10 gauge wire) to the trunk....
  28. Locoxp
    Locoxp
    Haha that's what known in the business as a cluster F*%k! love your work! to think how much time and effort I spent de looming my engine bay.
  29. Locoxp
    Locoxp
    I had a cut out solenoid from an aircraft in my boot too, that worked on a timer from the alarm and cut power if the ignition was off for more than 10 secs it really screwed anyone trying to start my car. yours looks more reliable though.
  30. gimpyshotrods
    gimpyshotrods
    I have my Konig Rewind's on order. They are an old-school Minilite look-a-like, for that 60's road-racer look. Can't wait!
