Technical crack in head of my 40 merc
Discussion in 'The Hokey Ass Message Board' started by redroaddog, May 5, 2014.
  1. redroaddog
    redroaddog
    so i found i have a exteral crack in the left head that is seaping a very minor amount of anti-freeze it never runs hot and was thinking of using some kind of block seal i've never used the stuff does it work? the motor runs so good i hate to open it up......Dave
  2. ROADSTER1927
    ROADSTER1927
    I wouldn't use block sealer for a crack you can see externally. Lock and s***ch pins or welding come to mind.
  3. redroaddog
    redroaddog
    its just damp seems to be coming from under oil filter up toward intake , not a crack i can see just damp after its warmed it
  4. black 62
    black 62
    from arkansas
    try some stop leak, works for years sometimes---Do Not tear it down unless you have to...
  5. bobss396
    bobss396
    Solder Seal Block Saver to the rescue, or something similar. I've seen it work many times, in fact my son's OT Nissan has been running around with a dose of it in the radiator for about a year now. That one was p***ing combustion gases into the coolant and over heating.
    Bob
  6. Hnstray
    Hnstray
    from Quincy, IL
    I do not understand the comments about "not tearing it down". It's a flathead, for goodness sake! The head comes off, is either repaired or replaced, and the head is reinstalled. Done! Aside from the coolant drain/ refill and a head gasket, nothing of consequence is disturbed.
  7. ROADSTER1927
    ROADSTER1927
    Sounds like a gasket or retorque or you need some sealer on a weepy stud.
  8. Bruce Lancaster
    Bruce Lancaster
    You said under the oil filter...there is a stud under there that is hard to reach. Get in there and tighten everything...there may be some nuts under there that were skipped at some point because they were hard to reach.
  9. redroaddog
    redroaddog
    i know your right but i live in murphy's world(what can go wrong will) so i will try a little stop leak first if i can make it thru the summer will pull the head in the fall.......thanks for the comments guys...Dave:cool:
  10. 19Fordy
    19Fordy
    Install a new head now to avoid surprises on the road. It's not difficult.
  11. ROADSTER1927
    ROADSTER1927
    x1 2 3 4---------
  12. Water gl*** or block sealer works well of you are in Stale Sandwich and need to get home. Be sure that you flush or good before you try it antifreeze is your enemy in this case. Pepper will get you home with a busted radiator as well. Niether should be considered a permenant repair.
    If you are at home and have a tool box then a real repair is probably in order.
  13. bobss396
    bobss396
    The stop leak will keep you rolling until you come up with parts and or a permanent fix. With summer.. best to fix it once and for all, start with the torque and sealant options.
    In my case, it recently worked well for a car not worth throwing a ton of money into.
    Bob
  14. black 62
    black 62
    from arkansas
    let me restate for the purpose of enhanced understanding "keep it running" unless it becomes a problem...
