Looking at 2 motors still in cars -one is clearly 'early" style 331 with rear mounted distributor. Engine numbers stamped behind wather pump read C53-8-18049 The other motor is supposed to be a 426. Large casting number on block p***enger side reads 24883304. Under that is DN R1. Can these help date the motor or are there other numbers I should look for. Trying to clean other areas up for more numbers.Thanks
Is the "Other one" a front distributor engine? The 331-392 series engines look clearly different than the 426.
Yes-Distributor is in the front-whole different set up from the older one which I've determined is a 331 of 1953 era. I've enclosed pictures of what I think is the 426
Hey guys-take a look at these pictures-Numbers on p***enger side of block say 2488330-1 DN RL Folks who have looked at it tell me it is a 426 Hemi. Cany you tell anything from these pictures? Car was built almost 40 years ago
What's the plan with the 426? I have a '65 coronet altered project that's in need of an engine. Also right under your coil should be a flat area cast in the block with info stamped into it. Posted using the Full Custom H.A.M.B. App!
