23 Hole salute to my heavy 32
Discussion in 'The Hokey Ass Message Board' started by ckdesigns, Dec 1, 2005.
  1. ckdesigns
    ckdesigns
    from Ogden,Utah
    So I aquired a heavy 32 axle for my tub (thanks Bellm) and decided that it needed some holes in it, 23 of them. 1" holes that are 2" center to center.
    Pics for your viewing pleasure.
  2. Slag Kustom
    Slag Kustom
    looks good but kind of risky putting holes on the outside of the perch holes.
  3. ckdesigns
    ckdesigns
    from Ogden,Utah
    I was debating the same thing but the axle is about 3/4" thick between the perch pin holes and the king pin holes.
    Oh ya the rolling bones guys' are drilled out there.
  4. Muttley
    Muttley
    Looks good....I hope strength wont be an issue. That wheel and tire combo is going to rule.
  5. Dirty2
    Dirty2
    Holly Molly that looks sweet !!!! Is it that bad to drill it out side the pearch ???
  6. Deuce Roadster
    Deuce Roadster
    Man.........putting holes in that old Heavy Ford axle.........you must have a GOOD milling machine.....
    Looks good .. :D
  7. 3wLarry
    3wLarry
    from Owasso, Ok
    Yup. Rolling Bones did mine. 23 one inch holes. Strength is not an issue with a big beam '32 axle.
  8. 30roadster
    30roadster
    sweet axle....isn't BellM a good person to know!
    ...and he's handsome too - XOXO Eddie:D
  9. Zodoff
    Zodoff
    Your right. after seeing that pic,I totally agree.
    plenty strong!
  10. ckdesigns
    ckdesigns
    from Ogden,Utah
    Now, if only mine was going under a 3 window like yours.
  11. Southfork
    Southfork
    So where did you have the 23 holes drilled/milled, CK? Or did you do it yourself? If you had a commercial vendor do it for you, what did they charge for all 23 holes?
  12. ckdesigns
    ckdesigns
    from Ogden,Utah
    I drilled them on a mill. I think places charge about $200 to do it. I was debating on doing it with a holesaw but am very glad I used the drill bit the axle is way thicker than a regular axle on the ends.
  13. gasheat
    gasheat
    from Dallas
    Great look. I love it.
  14. 3wLarry
    3wLarry
    from Owasso, Ok
    You're right. It was $200 to have mine done.
  15. HAHA I was wondering where the other 6 holes came from. I knew my drilled axle had only 17 holes.
    That one looks great undroped and drilled out on the ends. Not to mention all the other holes in the suspension;)
    Nice job.
  16. Chopped Tudor
    Chopped Tudor
    from DETROIT
    right on looks good
  17. 3wLarry
    3wLarry
    from Owasso, Ok
    Yeah... those damn metal-eating Moths play hell on old Ford parts.:rolleyes: :)
  18. BELLM
    BELLM
    WOW!! Looks good!! You don't waste any time! Looks a lot better than it did in my storage building, getting grease on me off the spindles every time I walked by.:D
    That 32 heavy axle is seriously meaty, holes outside perch should be no problem
    I don't have an immediate use for the superbell you swapped but I am going to go ahead grind the Superbell off, have my Buddy Keith drill it since he is in a drilling mood and will do it on the cheap. Probably take the Speedway tube axle out from under my roadster replace it with this one when I redo the car. I'm glad you are obviously happy with the trade.
    Hotwheel is going to kick my *** for getting rid of gennie 32 parts.
    Kyle, what can I say, you just like me 'cause I feed you Corona when you come visit! When you gonna bring 327 parts over so I can watch you build a bad*** engine?
  19. 3wLarry
    3wLarry
    from Owasso, Ok
    Ahhh...Coronas...my kinda guy. ;)
  20. Is that 32 axle a commercial one? I tried to buy one quite a few years ago and always thought that is wasn't a p***enger model. Wish the %#@%$#$ guy would have sold it to me. Looks really cool . . . and you can tell there is more than enough meat on it!
    Question: Did you use a carbide bit - I've heard those axles are plenty tough? What size bit did you start with?
  21. ckdesigns
    ckdesigns
    from Ogden,Utah
    I drilled 1/2" holes and then 1" holes with regular bits.
