Technical ‘35-40 Ford steering shafts, hardened or just round bar with a hole in
Discussion in 'The Hokey Ass Message Board' started by Budget36, Jan 29, 2025.
  1. Budget36
    Budget36
    Tis my question for the day;)
    Can a solid round bar be used, or not?
    Thanks.
  2. alchemy
    alchemy
    How are you attaching at the top and bottom ends? You don’t want junk bar for sure.
    Budget36 likes this.
  3. Dan Hay
    Dan Hay
    It’s stands to reason that perhaps a solid shaft would be more sturdy? You need that hole to run the ground wire for the horn, how are people gonna get outta the way? :)
    chevyfordman and Budget36 like this.
  4. rusty valley
    rusty valley
    You trying to make the whole thing, or splice together? I'm sure they are not hard, the angle part for the steering wheel is somehow pressed for shape, not machined. The bottom has very light splines for the worm gear, with a dead spot so it only goes on one way to keep it in time with the key for the wheel
  5. nobby
    nobby
    are you keeping the original steering gear box?
  6. They are "Not" hardened. When in doubt us a file for a test.
  7. Budget36
    Budget36
    To answer a few questions…
    I picked up a ‘40 box. Which was cut down.
    For length change, ie not as the ‘40 is/was, plan would be a machine shop for the taper and splines.
    I could cut the taper, but no means to support the box end out the rear of my lathe chuck.
    And after it’s tapered I don’t have means to make splines anyways.
    I could adjust the length of a ‘36 PU shaft vs a machine shop cost, but wanted to get information ahead of time.
    Thanks
  8. Budget36
    Budget36
    This is using cross steer in a ‘32 Dodge PU with a ‘46-48 drop tubes front axle.
    The Dodge had side steer.
  9. rusty valley
    rusty valley
    You could pull the worm off to fit in your lathe, However I don't think the Ford shaft has thick enough wall to cut the taper for a Ford steering wheel, there will not be enough meat left for strength. Again, I think Ford formed that part with a press and a die, not machined. You mention splines on top? for a GM type steering wheel? The top spline could be rosett welded with a sleeve made by you inside.
  10. Budget36
    Budget36
    @rusty valley , the reply about splines was in regards to the steering gear being splined.
    I’ve a wheel in mind to use
  11. 31Apickup
    31Apickup
    Weedetr sell shafts of several lengths
    olscrounger and Budget36 like this.
  12. Budget36
    Budget36
    Now that solves that!
    Thanks!
  13. nobby
    nobby
    Steering Shaft Kit for 35-41 Ford Pickup
    Steering Upgrade Kit for 35-39 Ford w/Axle Front
    if you are after a sloid shaft with a gm taper and spline
    buy the borgeson inner shaft for a 57 chevy pas conversion 31.25'' long end to end, with 36 spline 3/4 on the bottom
    IF the steering wheel you choose is ford,
    get the splined tapered inner shaft from borgeson for 66 mustang pas conversion
    Replacement Steering Column Shaft for 1955-1957 Chevy | Borgeson Universal Company > Borgeson Universal Company
    Steering Column Shaft for 62-66 ChevyII > Borgeson Universal Company
    Column Shaft / Floor Mount, 65-67 Mustang > Borgeson Universal Company
    plus
    are you aware of the differences between
    a worm and pg
    worm and roller
    twin helical ba;ll bearing
    steering box?
