Technical ‘37 Ford pickup - need original brake linkage photos
Discussion in 'The Hokey Ass Message Board' started by Poppinjohnnies, Jul 4, 2024.
  1. Poppinjohnnies
    Poppinjohnnies
    Dad took hundreds of pictures of his ‘37 pickup as he disassembled it for the restoration, but lost them all when he updated his IPhone (no, he didn’t back it up). Anyway, does anyone have pictures of the mechanical brake linkage for a ‘37 half ton? I assume that the cars were similar. We are in need of info from the brake pedal to the hubs.
  2. Deuce Lover
    Deuce Lover
    Suggest you go on fordbarn.com Early V8 section. It is the sister site to this . It's more about the bone stock flathead Fords.The members there will be of a big help.
    Poppinjohnnies likes this.
  3. JohnLewis
    JohnLewis
    [​IMG][​IMG][​IMG]
    Part Number Description
    13512 Clamp, Stop Light Switch Chain
    2011 Plate Assy, Front Brake Housing
    2019 Shoe and Lining Assy
    2021 Lining, Brake Shoe
    2036 Spring, Brake Shoe Retracting
    2038 Stem, Brake Shoe Adjusting
    2041 Wedge, Brake Shoe Adjusting
    2042 Link, Brake Shoe Adjusting
    2043 Cap, Brake Adjusting Bracket
    2045 Pin, Brake Shoe Roller
    20489-S Hex Bolt, 3/8" -24 x 1-5/8"
    2050 Wedge, Brake Operating
    2052 Bolt, Front Brake Operating Wedge
    2054 Washer, Brake Operating Stud
    2075 Pin, Front Brake Operating
    2076-RH Shaft, Front Brake - Right Hand
    2077-LH Shaft, Front Brake - Left Hand
    2078 Housing Assy, Front Brake Shaft
    2084 Lever, Front Brake
    2087 Ring, Front Brake Lever Dust
    2211 Plate and Bracket Assy
    2216 Bolt, Rear Brake Housing Plate
    2227 Bushing, Front Brake Shaft
    2240 Baffle, Rear Brake Grease
    2250-RH Shaft, Rear Brake Operating - Right Hand
    2251-LH Shaft, Rear Brake Operating - Left Hand
    2252 Stud, Rear Brake Operating Wedge
    2254 Spacer, Rear Brake Operating Wedge Stud
    2454 Pad, Brake Pedal
    2455 Pedal and Bushing Assy
    2462 Rod, Brake Pedal to Cross Shaft
    2466 Eye, Brake Rod Adjustable
    2467 Bracket, Clutch and Brake Pedal
    2472 Spring, Brake Pedal Retracting
    2485 Shaft Assy, Service Brake Cross
    2495 Rod, Rocker Arm to Front Brake
    2499 Rod, Service Brake Cross Shaft to Rear Axle
    2503-RH Support, Rear Brake Rod - Right Hand
    2504-LH Support, Rear Brake Rod - Left Hand
    2520 Bracket, Front Brake Rocker Arm
    2521 Arm, Front Brake Rocker
    2600-LH Plate Assy, Hand Brake Carrier - Left Hand
    2600-RH Plate Assy, Hand Brake Carrier - Right Hand
    2610 Band, Hand Brake
    2620 Lining, Hand Brake
    2624 Spring, Hand Brake Band and Lever Retracting
    2628 Link, Hand Brake Toggle
    2632 Link, Hand Brake Toggle Connecting
    2636 Lever, Hand Brake Toggle
    2639 Pin, Hand Brake Lever Sleeve
    2644 Bushing, Rear Brake Extension Lever
    2646-RH Lever, Hand Brake Extension - Right Hand
    2647-LH Lever, Hand Brake Extension - Left Hand
    2780 Lever Assy, Hand Brake
    2785 Rod, Hand Brake Lever Pawl
    2786 Pawl, Hand Brake Lever
    2795 Sector, Hand Brake Lever
    2828 Shaft Assy, Hand Brake Cross
    2835 Pin, Transfer Lever
    2845 Bracket, Hand Brake Cross Shaft
    2853 Rod, Hand Brake Lever to Cross Shaft
    2864 Rod, Hand Brake Cross Shaft to Rear Axle
    33800-S Hex Nut, 3/8" -24 (21/64 x 9/16")
    33923-S Hex Check Nut, 5/16"-24 (3/16" x 1/2")
    34033-S Castle Nut, 9/16" -18 (5/8" x 7/8")
    352050-S Flat Head Rivet, 9/32" x 1-1/4"
    353027-S Lubricator Fitting, Staright 1/8"
    353047AS Lubricator Fitting, Check Valve Type 1/8"
    45218-S Stamped Nut, 3/8" -24
    4906 Bushing
    72009-S Cotter Pin, 3/32" x 5/8"
    72010-S Cotter Pin, 1/8" x 5/8"
    72034-S Cotter Pin, 3/32" x 1"
    72035-S Cotter Pin, 3/32" x 1"
    73889-S Clevis Pin, 3/8" x 7/8"
    73919-S Clevis Pin, 3/8" x 1-1/8"
    73931-S Clevis Pin, 5/16" x 31/32"
    73955-S Clevis Pin, 5/16" x 1-7/16"
    97012-S Clevis, 5/16"-24 x 2-1/4"
  4. BJR
    BJR
    Now would be a good time to convert to hydraulic brakes.
  5. Poppinjohnnies
    Poppinjohnnies
    Thank you, thank you!!! That info is extremely helpful! Yes, it would be a perfect time to convert it to juice brakes, but he wants to keep it original. Now, the '36 that I'll be working on shortly will be a different animal....
  6. Toms Dogs
    Toms Dogs
    from NJ
