Projects ‘39 Ford Deluxe Coupe build
Discussion in 'Traditional Hot Rods' started by dugydog, Nov 29, 2023.
  1. Adriatic Machine
    Adriatic Machine
    That looks great, and with room for more. Glad to see you moving forward
  2. dugydog
    dugydog
    Well it’s been some time since I updated my 1939 coupe build but I finally took a break from a m***ive landscaping project at home and started working on the car again. I picked up some tires at Hershey 7.10 x 15 for the rear and 5.6 x 15’s for the front. I finished welding the rear spring perches to the rear after I got my pinion angle set and also welded the shock brackets and installed the rear shocks. Then took my original ‘55 Chevy driveshaft to the shop and had it cut and balanced. After installing the driveshaft I moved to the rear brakes with new brake cylinders, drums, emergency brake cable (used but excellent condition) and made some new brake lines across the rear. I rolled the car out of the garage and mocked up the front end to get a better look. I love the way the rear tires fit but the stance is not to my liking as it’s way too high up front. I’m guessing I need a dropped axle.
    woodz, mvee33, Jacksmith and 7 others like this.
  3. The37Kid
    The37Kid
    Looks great, nice clean looking project. Where ae you on the Island? Bob
  4. dugydog
    dugydog
    I’m out on the North Fork in South Jamesport
  5. The37Kid
    The37Kid
    Ok, now that the leaves are off the trees I have a better view of Oyster Bay on the North Shore that is 45 miles away as the crow flies.
  6. It's always nice seeing things come together but, looks like you still have a lot of weight to add before your at loaded curb weight. I'd hold off ordering the dropped axle yet myself.
  7. bobss396
    bobss396
    I was just out your way last week. Took a ride out to Orient to get pumpkins, etc.
  8. dugydog
    dugydog
    Oh, that was you?
    bobss396 and patsurf like this.
  9. Adriatic Machine
    Adriatic Machine
    Car looks great! Rolling it out and getting a good eyeful is always a proud moment.
  10. okiedokie
    okiedokie
    from Ok
  11. dugydog
    dugydog
    Back to work on the brakes. I went with Speedway’s ch***is mounted master cylinder mostly because I didn’t have much room to work with on the firewall. Overall I was pretty happy with the install as it bolted up quite nicely to the pre-existing holes in the X member. The hardware in the kit however was complete junk. Even after using a thread chaser on both the nuts and bolts they still were not going together without resistance so I just used some from my bolts bin. The rear brake lines are now plumbed. I picked up some F1 hubs, backing plates, and drums so once I get those installed I’ll work on the fronts.
    bobss396 and Adriatic Machine like this.
  12. patsurf
    patsurf
    thought you'd put a condulet under there!--smooth
  13. 19Fordy
    19Fordy
    Tom, Set the car - all 4 tires on the ground - to really see how the wheels look in the wheel well and fender contour.
    Make sure fenders are bolted tight.
