Technical ‘39 Ford transmission (and later years)
Discussion in 'The Hokey Ass Message Board' started by Budget36, Jun 14, 2023.
  1. Budget36
    Budget36
    I recall a post by @Mac VP saying the internals from ‘39-48? Are the same.
    Question I have is the ‘39 looked for/sought after, etc because it stick shift vs column shift? Ie say in closed driveline years, did Ford from 40-on move to column shift for 3 speeds? I’m not referring to open drive transmissions, just closed drive.
    No real “need to know” other than a curiosity:)
  2. ronzmtrwrx
    ronzmtrwrx
    If I recall correctly, the 39 top will have the 3” shift fork, which will work with the innards of a 40 and up side shift. (Column). And yes the closed drives 40 and up were column shift, excluding the later light pickups with the open drive, some floor shift, some column shift. Someone will correct me if I’m wrong. Lol.
    Budget36 likes this.
  3. 51504bat
    51504bat
    Not positive but not all '39 trans had the 3 inch fork. Others will know for sure.
  4. railcarmover
    railcarmover
    Top loaders were used in pickups up to ‘52. Open driveshaft. They have all the goodies, dual detent shift tower, later synchros and a main shaft that isn’t like a rubics cube.
  5. railcarmover
    railcarmover
    98272D8A-C39C-41B9-A50F-537F4F0FDC61.jpeg I’ve got a few of them
    51 mercules, ronzmtrwrx and Budget36 like this.
  6. John Heckman
    John Heckman
    from Lanexa, VA
    I just built a “39” trans. Using a 78 case, added 1948 side shift gear set, shift tower is double detent 81A with the 3” fork (91A). It’s going on my modified 1930 Tudor. Closed driveline.
    51 mercules and Budget36 like this.
