Projects ‘41 ford pickup project
Discussion in 'The Hokey Ass Message Board' started by olskool34, Dec 23, 2023.
  1. 40Standard
    40Standard
    from Indy
    liked the build, truck looks nice
    olskool34 likes this.
  2. Rand Man
    Rand Man
    You do good work.
  3. Fortunateson
    Fortunateson
    Great work and I .earned a couple of things. Did you mig or tig? The reason I ask is that I’ll be doing something similar on my 5W rear fenders.
    Good to see the “original” Chevy engine was kept! LOL
  4. hotdamn
    hotdamn
  5. Rob28
    Rob28
    from Calgary AB
    Great looking truck! Nice stance as well I can spot the 2040R spring what are you using for your drop axle?
  6. Toms Dogs
    Toms Dogs
    from NJ
  7. 54reno
    54reno
    Awesome! Nice job, that truck is perfect.
  8. theman440
    theman440
    from Las Vegas
    Nice job, Id rather see a flathead or a "baby" hemi but I like it.
    34 5W Paul and olskool34 like this.
  9. olskool34
    olskool34
    Thank you!
  10. olskool34
    olskool34
    I mig weld. You can’t go hog wild. Small welds and cool to prevent warping. Also really close gaps are key.
  11. olskool34
    olskool34
    Got the axle from Sid. Great guy to deal with.
  12. olskool34
    olskool34
    Wiring is underway. I have a cover over the carb, just not in the pic. Don’t want to drop anything down it. IMG_8222.jpeg IMG_8223.jpeg
    JalopyJimbo likes this.
  13. John Tumolo
    John Tumolo
    Great build. Glad the grill found a good home. JOHN
  14. Rob28
    Rob28
    from Calgary AB
    perfect I have been getting one ordered up with him. Do you know if he narrowed it a bit to compensate for your disk brakes? Also did he just drop your steering arms as well?
  15. ***Area-51***
    ***Area-51***
    from Ohio
    Nice job, well done!
    What are running for steering box?
    Any trouble running the exhaust around the steering box with those manifolds? any closer pics of that?.....Looks good
  16. Motorwrxs
    Motorwrxs
    When Sid my axle for my 57 truck he did the steering arms as well as replaced my kingpins…
  17. olskool34
    olskool34
    It was not a stretch drop. I dropped the spindles myself.
  18. olskool34
    olskool34
    Box is a Saginaw 605 P/S unit. Yes the pipes took some thought to route with the box/oil filter. I will take a pic for you.
  19. olskool34
    olskool34
    jaracer likes this.
  20. Hotrodderman
    Hotrodderman
    Great job on the build! The front cowl inner fender patch, did you spot weld or plug weld on the fender well part? The blend on the rear fenders looks good.
  21. brady1929
    brady1929
  22. ***Area-51***
    ***Area-51***
    from Ohio
    Nice work!
    One more thing if you don’t mind,
    who’s wiring harness did you use?
  23. olskool34
    olskool34
    Thanks! The front lower cowl was **** welded at the seams and plug welded where it meets the firewall/inner rocker patch.
  24. olskool34
    olskool34
    I am using the cloth covered 12 circuit harness from Speedway. I am almost finished and the only issue I had was the dimmer switch and brake light switch bundles were not long enough to reach the switches. Everything else was more than long enough.
  25. manyolcars
    manyolcars
    Tell us about that
  26. ***Area-51***
    ***Area-51***
    from Ohio
    Thanks for the info, interesting build....keep us posted.
  27. olskool34
    olskool34
    Heat them up red hot with a rosebud tip and slowly move them to where they need to be. Let cool on their own.
    JalopyJimbo and Rob28 like this.
  28. 1pickup
    1pickup
  29. NealinCA
    NealinCA
    Been following along on IG, but glad you posted the build thread here. Really nice save on this one, and the overall look and stance is perfect. Well done!
  30. olskool34
    olskool34
    Thank you very much. First time firing that crate engine up was today and it did not disappoint.
