Technical ‘63 impala wipers not working
Discussion in 'Traditional Customs' started by Eth727, Sep 1, 2024.
  1. Eth727
    Eth727
    Hey guys so my wipers on my ‘63 impala aren’t working. I removed the switch and cleaned it inside and out. I removed the motor and bench tested it and it worked.
    I reinstalled it and it didn’t work. I cleaned the brass ground strap and tested it by using a seperate wire onto another ground and it worked but switch wouldn’t turn it off. Any ideas on how to test the switch. The motor works and parks properly when bench tested.
  2. goldmountain
    goldmountain
    If I remember correctly, on GM cars power is sent first to the wiper motor and then the switch to ground.
    jaracer likes this.
  3. Eth727
    Eth727
    It’s weird the 3 bolts that hold the motor on have rubber insulators around them with a brass ground********* one.
  4. TrailerTrashToo
    TrailerTrashToo
  5. Eth727
    Eth727
    Oh okay so the switch might not have a good ground?
  6. Eth727
    Eth727
    So I scraped off the paint on the dash reinstalled the switch and still doesn’t turn on.
  7. wheeltramp brian
    wheeltramp brian
    Try connecting the wire that goes to the switch to a ground to eliminate a bad switch
    NoSurf likes this.
  8. jimmy six
    jimmy six
    Most out here take off the arms and blades then stick a pair of chrome plated do-hickies over the splined actuators…and use Rain-X
  9. Eth727
    Eth727
    So I tried two switches and they both make the motor click, low speed, high and spray. Bench testing the motor and it works fine and parks.
  10. INVISIBLEKID
    INVISIBLEKID
    from Gilroy,CA
    Check dirty connections........Either switch side, or motor side........
  11. Eth727
    Eth727
    That’s the first thing I did.
  12. goldmountain
    goldmountain
    Check for continuity in the wires from the motor to the switch.
  13. flyin-t
    flyin-t
    Did you check the 20 amp fuse?
