Technical 1” lug nuts
Discussion in 'Traditional Hot Rods' started by Choppedcoupe, Dec 24, 2024.
  1. Choppedcoupe
    Choppedcoupe
    I’ve got some 1940 Ford wheels that came with my car. The lug nut tapers aren’t cracked, but seem very worn. There were tapered washers in place the first time I took off the wheels. I’d still like to use these wheels, but the little tapered washers are kind of a pain to deal with. I’m thinking that it might be wise to run some larger-than-stock lug nuts, and that all should be fine if I do that just as a precaution…
    does anyone know a good source for 1” lug nuts?
  2. alanp561
    alanp561
    Here you go: upload_2024-12-24_10-0-13.png
    '29 Gizmo and X-cpe like this.
  3. BooBoo63
    BooBoo63
    I used those 1'' lug nuts on my street stock circle track cars with all manner of wheels over the years. stock wheels and racing style wheels and never had an issue with them. They were 99 cents back then. Any racing supply catalog will have them. Speedway motors would is a reliable source. just go with them.
    bobss396 and Just Gary like this.
  4. flatout51
    flatout51
    I've used the Speedway ones and some from Amazon. Same parts. Work great on early ford wheels.
  5. alchemy
    alchemy
    Check the degrees of the taper on the wheels before you buy lug nuts.
  6. RodStRace
    RodStRace
    After the past 6 months trying to find good cheap vintage wheels, I get that what was once a fairly simple task is getting harder.
    With all the welding and fixing this group does to bodies, ch***is and engine parts, I'd guess that with a bit of setup you could weld then spot face the lug holes evenly.
    Yes, you would have to set stops on your drill press or mill, and you'd want to use appropriate filler rod, then repaint.
    deathrowdave and Just Gary like this.
  7. deathrowdave
    deathrowdave
    from NKy
    I have done a few wheels , weld , touch with a tapered grinding stone , then spot face as good as new
    RodStRace likes this.
  8. rusty valley
    rusty valley
    If the hole is enlarged, make sure the nut is not bottomed out before pulling the wheel up tight
    RodStRace and '28phonebooth like this.
  9. What @rusty valley said. But there is salvation if they do bottom out..... Shorten the 'nose' of the nut to effectively enlarge the seat diameter.
    rusty valley likes this.
  10. rusty valley
    rusty valley
    While we're on the subject of nuts, I'd be nuts to not mention the thread depth on the nuts, and thread hight on the stud. If you look at an original Ford nut the bottom few threads are missing, and its drilled large enough to clear a stud that may have the thicker un threaded shank higher than the drum. Many aftermarket nuts are just threaded all the way through, it may bottom out on the shoulder before pulling the wheel tight.
    RodStRace, '28phonebooth and alanp561 like this.
  11. 29Sleeper
    29Sleeper
    from SoCal
    If your wheels are powder coated the washers will help to not chip the paint. They don't rotate when you tighten the nut.
  12. mongo4u2
    mongo4u2
    from sparta
    I use the fine theaded ones in Nascar now. course are for dirt track stuff
  13. 29Sleeper
    29Sleeper
    from SoCal
