Technical 1-1/2 chop
Discussion in 'Traditional Hot Rods' started by GCDC, Feb 15, 2021.
  1. GCDC
    GCDC
    Thinking of chopping my 33 pickup 1-1/2 .
  2. HotRod33
    HotRod33
  3. Jalopy Joker
    Jalopy Joker
  4. HOTRODPRIMER
    HOTRODPRIMER
    Check this thread out, there is 29 pages dedicated to 32-34 Ford pickups, you should be able to find something there that get's you motivated to cut that top or decide not too. :D HRP
    32-34 Ford trucks
    dana barlow, Budget36 and GCDC like this.
  5. adam401
    adam401
    1-1/2"? Thats like dry ******* your girlfriend homeboy. Cut that ****. I suggest a nice healthy 6" chop. You owe me a beer now
  6. Unique Rustorations
    Unique Rustorations
    Have to agree with Adam401 on the 1 1/2” chop. Better yet take a high def side pic and put it on the Photoshop thread and let Mr. Themoose or Madfish do their magic on it so you can actually see what your truck will look like? Regards, Randy
    GCDC and VANDENPLAS like this.
  7. Before you cut have you figured out a lower seat? Im 6ft1",and I look out the top 2 inches of the windshield of a stock cab 32.Doesnt make for a comfortable long ride truck.
    nunattax, GCDC and Budget36 like this.
  8. GCDC
    GCDC
    I am 6ft3” that’s why I am thinking no chop
  9. goldmountain
    goldmountain
    Chop it some more. Think of the money you will save on the gl***.
    Maicobreako, GCDC and Budget36 like this.
  10. A lot of work for a slightly to no noticeable difference. Better off with a nice lowering job, the right wheels and tires with full fenders and stock roof. It would look good.
  11. themoose
    themoose
    This should be about 1 1/2
  12. krylon32
    krylon32
    from Nebraska
    I've built 4 deuce pickups, the first one was chopped 2.5 inches, the second 4 and the last 2 were 3 inches. My favorite for a highboy or full fendered pickup is 3 like the green one I have listed in the for sale section. For a channeled pickup I like 4-5 inches. This is just the ramblings of an old hot rodder.
  13. HOTRODPRIMER
    HOTRODPRIMER
    6' 4" and no chop. HRP
  14. Jacksmith
    Jacksmith
    from Aridzona
    I've had luck in the past with proportion; In other words, let the design of the existing vehicle determine the modification rather than slamming a heavy chop just to have it chopped.
    I measure from the window-sill, where your arm rests, to the bottom of the door. Divide by 2. Make the chop so that the dimension from the top of the roof to the window-sill is equal to 1/2 the sill to door bottom dimension. (Did I explain that right?) It almost always looks natural to the point where, un-cut doesn't look right... like it's wearing a top hat.
    In a small cab, it gets a little "hunchy" behind the wheel if you go too low. I've had to lower the seat somehow to fit a 6 footer in. That's Hot Roddin'!
  15. Unique Rustorations
    Unique Rustorations
    Within two pages you should have your answer. Experience and real world suggestions to yours actually chopped 1 1/2”. The H.A.M.B. got it done IMO! Nice work all. Randy
    themoose likes this.
  16. continentaljohn
    continentaljohn
    I vote no chop as it get tight in the cab on longer trips 1B145F1E-5F63-4425-BF07-CAF442554EAE.jpeg
  17. fastcar1953
    fastcar1953
    Gl*** but suppose to be 4 inch chop with 4 inch channel. Cab is stretched 8 inches. I have done long trips but it is not comfortable. I'm 5 10. 11.jpg
    Jalopy Joker likes this.
  18. blowby
    blowby
    from Nicasio Ca
    Perfect proof these look absolutely righteous as is.
    olscrounger and continentaljohn like this.
  19. Yea I would go 1 9/16 anyway.
    I am all over the board on choping one, Gentleman's chop to hammered to the max. I chopped an A once 2", yes it was the same work as if I chopped it a ton. But it changed it just enough to make people wonder what had been done.
  20. Kiwi 4d
    Kiwi 4d
    Two generous size lads try out our stock 32 , bit of a comedy watching 6’5 “stretch” pulling his legs in . Then 6’4” “TC” also . Both these guys have big hands ,so not much clearance between dash and steering wheel .
    32A2F43B-123C-467A-9DF6-2EEDE90ACF94.jpeg EFE82969-B0A5-4F53-9BC8-48E092FA1EC6.jpeg
  21. whiteknuckle
    whiteknuckle
    from Dryden, NY
    Can't remember exactly, either 2 1/2 or 3" chop. Doesn't leave a lot of room inside with 5" channel
  22. sawbuck
    sawbuck
    from 06492 ct
    4 inch chop...5 inch channel ...about 8 inches outta the bed
    kadillackid and Jalopy Joker like this.
  23. Love your back-yard. :cool:
  24. Budget36
    Budget36
    Sit in it. Get a comfortable seat height. Figure out head room. Nothing worse than driving with your neck bent forward, might look cool with a 6 inch cut. You also might hate driving it as well.
  25. ct1932ford
    ct1932ford
    Don’t waste your time! JMO. Go four or go more[emoji6]
  26. Blake 27
    Blake 27
    My friend Joe chopped this cab in 2007, unfortunately he can't remember exactly how much.
    He thinks between 1 1/2"-2". HPIM1439.JPG HPIM1440.JPG HPIM1488.JPG HPIM1497.JPG HPIM1498.JPG
    Frankie47, mcsfabrication and GordonC like this.
  27. GordonC
    GordonC
    Nice metal work on that cab!
  28. fleetside66
    fleetside66
    Yeah, a lot depends on your size, but 1-1/2" ain't much, especially considering there's no channel mixed in there. I did mine 3" with a 5" channel, but I did a lot of real life fitting in the sitting position, in relation to the steering wheel, the shifter, the brake pedal, clutch pedal, E-brake handle, the rear & side view mirrors, etc., before I pulled the trigger on taking a cutting wheel in my hands. Get some cardboard & sit in the truck & mock up where the top of the windshield & side windows would be, to see how it will all feels in a real situation.
  29. TCATTC
    TCATTC
    That thing is perfect "as is"
    olscrounger and Kiwi 4d like this.
  30. Roothawg
    Roothawg
    I would think 2.5-3" would be about right. Gene Winfield says 3.5" or leave the saw in its case.
