1/2 inch fuel line question.
Discussion in 'The Hokey Ass Message Board' started by SON OF GODZILLA, Nov 29, 2009.
  1. SON OF GODZILLA
    SON OF GODZILLA
    I have 1/2 inch fuel line from my high volume fuel pump to the back of my truck. But the new fuel tank has 3/8 line coming out of it. Can I just buy a reducer to run in line to make the 1/2 stuff work?
  2. squirrel
    maybe, maybe not. Need more info.
  3. flamedabone
    flamedabone
    Yes, you can use a reducer, but it kinda negates the benifit of teh 1/2 line.
    The best way to do it is score the correct fitting for your tank. Summit, Jegs or maybe even your local hydraulic shop should carry Aeroquip style A-N fittings, you will need a -8 bulkhead.
    Good luck, -Abone.
  4. ridin dirty
    ridin dirty
    8AN is actually 7/16 line size. Everybody calls it 1/2". Measure a 8an id fitting.
  5. Tell us a bit more about your combo/ride?
    Do you really NEED a 1/2" fuel line ?
    Rat
  6. junkyardroad
    junkyardroad
    from Colorado
    It would have to be one hell of an engine for a street motor to need 1/2.
  7. SON OF GODZILLA
    SON OF GODZILLA
    I think I have it figured out. The truck originally had a fuel cell in it so the PO ran 1/2 line up to the fuel pump. I put an original tank back in it but it has about 1 1/2 ft of 3/8 hard line attached to the sending unit. I didn't think I would have to change the line and all the fittings, just put a reducer right at the fuel sending unit line, where the 1/2 hard line starts.
  8. Paul2748
    Paul2748
    You should be able to get a compression fitting that has 3/8 on one end and 1/2 on the other. Should also be able to get a flare fiting the same way. Unless you are running high pressure pump like for fuel injection, the compression fitting will be ok. I've used this guy :http://www.br***catalog.com/catalog_browse/index.php?p=Cart/speedorder&s=www.fittingsandmore.com
    They show a br*** compression union 1/2 and 3/8, part #18-081.
  9. Nixer
    Nixer
    here is how I plan set mine up...if it helps at all.
    Tank to fuel filter - 3/8th hard line (approx 6 inches)
    Fuel filter to electric red holley fuel pump - 3/8th line (approx 4 inches)
    Fuel pump up to general engine area 5/16th hard line (probably 10 ft or so)
    Transfer to rubber hose (1 ft)
    Rubber hose to ******d smaller inline fuel filter to carb (few inches)
    I am pretty confident you shouldn't have a problem.
    Tok
