1/4 eliptical front
Discussion in 'The Hokey Ass Message Board' started by nomobux, Dec 15, 2003.
  1. Here goes again for a friend. Working on some kind of a old mopar track rod. Question is .. does that type of front end need any kind of radious rods or what ? TIA
  2. AnimalAin
    AnimalAin
    To summarize, yes. Needed to locate the axle about the transverse axis. Many use split bones, although hairpins or four-bars will work as well. Darrell Zipp uses four-bars on his; as I recall, his competitor with the model A roadsters uses hairpins. Both have had ink in magazines enough that you can find some reference pics.
  3. Zodoff
    Zodoff
    If not,you will get a " 1/4 epileptical front".....
    Guess the leaves can be mounted out wider on the aksle,than the frame,that will give some sideway support.But u still need some bars of some kind.
  4. lakesmod
    lakesmod
  5. nobux
    nobux
    Here's my attempt using a 35 axle w/split bones and homemade springpacks.
  6. thanx for the info so far guys. I will pass it along
  7. Morrisman
    Morrisman
    from England
    lakesmod,
    Is that the same car I saw on www.danielstrohl.com??
    Got any more pics of it finished?
  8. lakesmod
    lakesmod
    Morrisman-Ya,it's the same car as on dan's site.
    There are more pictures at
    http://starblvd.net/lakesmod
    It's not done yet,I do things as I can get some over time at work. Still 1-2 years away from hitting the street.
    I have more pictures I could e-mail you,what do you want to see?
    Fred
