1/4 plywood & mdf gauge panel???
Discussion in 'The Hokey Ass Message Board' started by Dan, Nov 16, 2011.
  1. Dan
    Dan
    playing around with making a gauge panel out of 1/4 ply and mdf but I plan on painting it when done, will primer and bondo "cover" the wood grain (of the ply) when painted, will it fill the "end grain (for lack of better description) of the mdf? Want it to come out looking one solid piece...thanks-
  2. Never2low
    Never2low
    High build primer should do the trick.
  3. sawzall
    sawzall
    if its just a gauge why do you need it to be filled?
  4. Dan
    Dan
    it will have raised and relieved surfaces, I want it to basically look like one solid piece of "cast" material...
  5. dana barlow
    dana barlow
    from Miami Fla.
    1. Y-blocks
    Wood,plywood with age shrinks and any paint will always have a hard time staying nice on wood. Make your panel of metal,or cover it with some thin metal so paint will stay fairly nice longer.
  6. Never2low
    Never2low
    If you don't want to/can't fab the panel out of metal, MDF is the better chioce over plywood. MDF does not shrink or warp, unless satuated with liquid. Scuff any surfaces you plan on adhearing bondo to, to give it something to bite into. High build primer will hide the end grain. Painting it after you cut all your holes, will make it as water resistant as possible. I've worked with MDF for over 15 years in the car audio world, it's great stuff as long as you know how to work and finish it. Hope this helps.
  7. Rusty O'Toole
    Rusty O'Toole
    Sculpt the shape you want in plaster, make a mold and cast it in fibreglass. Plywood or MDF will not last in an open car although they will last for 10 years or more in a closed car.
  8. appaRATus
    appaRATus
    What if you used MDO?
    It is laminated to hide the wood grain and is designed to be painted over.
  9. Paul
    Paul
    Editor
    if kept at a consistant humidity and temperature it should last a decade or so
    how about making it like you suggest but using that as a plug to create a mold to lay up a glass dash?
  10. rockdawg
    rockdawg
    from nj
  11. greazy john
    greazy john
    do like rockdawg suggests ..
  12. Can I make an observation with out the touchy feely police making a drama thread out of this?
    The wood dashboards on british imports used to be ply wood with a hard wood venir. I have seen many over the years that were just as solid as the day they left the factory. Many 30 or 40 years old, and a lot of them in the Pacific North West.
    OK that doesn't answer the question. Dan first you need to get some sealer of some sort on the wood to keep it from absorbing the primer, then if you are patient you can use high build primer to hid the grain prior to painting. Donot completely seal it up leave the back side untouched or it will dry rot. It has to breath.
  13. What porknbeaner said!
  14. Dan
    Dan
    thanks for the info.
    gonna start today making a hammer form, making one completely out of wood, one just cut from sheet metal and I am going to look into that video - fiberglass is another thing thing I know NOTHING about so am gonna play with that idea as well...thanks-
  15. Dan
    Dan
    http://www.youtube.com/watch?v=G8cz_5eP81U
    thats pretty cool. lots of possibilities there
    that guy applies bondo as smooth as I do :)
    I had the sound turned off as I am waching this while the kids are working so maybe he covered this but what would I use as a "mold release" if I wanted to use the mdf as a "plug" and make a fiberglass part to pull off of it?? thanks-
  16. Just your standard fiberglass release agent. I don't remember if it has a real name but you get it where you buy your glass supplies.
  17. TomWar
    TomWar
    whenever I'm doing a one-off plug and mold, I use several coats of turtle wax or any wax with carnuba base for a release agent.
    (Many years in the boat industry).
  18. Slick Willy
    Slick Willy
    Theres also the products called Medite and Medex, these are high moisture area and water resistant plywoods similar density to the MDF. good lumber yards and sign shops should have these.
  19. alchemy
    alchemy
