Technical 1 (800) Loud Pedal
Discussion in 'The Hokey Ass Message Board' started by Bandit Billy, Mar 22, 2016.
  1. Bandit Billy
    Bandit Billy
    I needed a throttle pedal for the 1-800 special so I opted out of the main stream and bought the Offy pedal. What a rattle trap. Like everything else on the car I decided it needed my touch so I started by sanding the bejeevus out of the piece to prepare it for polishing. Then I decided to add bronze bushings to the main fulcrum joint and the center piece. There is a full shoulder bolt running through those bushings so the bolt threads wont wear the bushings prematurely. Sorry for the fuzzy pic
    I also added nylon bushings to the pedal pad to tighten it up a bit. Drilled some lightening holes and then ran it across the buffer.
    Added some polished hardware during re-***embly. The end result I will mount in the car this evening. Still works smooth and easy but no rattle, no side to side movement and not the typical s****. A loud pedal worthy of being part of my roadster.
  2. alchemy
    alchemy
    Much improved.
  3. DDDenny
  4. Texas Webb
    Texas Webb
    Not much pedal pressure aye.
  5. Max Gearhead
    Max Gearhead
    from Wisconsin
  6. J. A. Miller
    J. A. Miller
    from Central NY
    You took the words out of my mouth Max. Lol
    Max Gearhead likes this.
  7. David Gersic
    David Gersic
    from DeKalb, IL
  8. Jalopy Joker
    Jalopy Joker
    better wear clean boots to set on that pretty piece
  9. Bandit Billy
    Bandit Billy
    Tex, if you worry about busting an aluminum gas pedal in half with your heavy right foot you might want to:
    a. Use less weight on the leg extensions at the YMCA,
    b. Consider upping your lower end torque,
    c. Possibly removing a half dozen of your return springs...I mean, damn.
    JJ, the brake and clutch pads match. I am considering buying some stock in Mother's Aluminum Polish. Anyone know their NYSX symbol?
    Mr. Denny, thanks as always fellow NW'er. Now you know why I want to drill the clutch and brake levers.
