Hello honkies, got another question for yall, The car is a 51 chevy business coupe. Sometimes when I hit the brakes the right rear wheel will lock up even with very light pedal pressure, I dont know why, any ideas?
brake fluid leak i bet, even a small amount of brake fluid on the brake shoes will cause it to lock up.
x2 on the contaminated shoes. Had a car come in with a similar issue. Found that it had been leaking just a little for a long time and had de-bonded the linings. Lucky it came on a truck! fresh cylinders and linings and good as new. could be a crushed pipe on the other side also, but probably wet lining
Had a similar problem with my 59, right rear would lock up even going 10 miles an hour. Found out I had a leaky (blown out) axle seal, and my brake shoes were out of adjustment by quite a bit. Changed the rear seal, adjusted the brakes, haven't had a problem with it locking up since. Good luck man.
That is a possibility. Also look to see if the hardware is on right and look at the backing plate to see if its badly grooved. A shoe can hang up in the groove and take a while to retract. Most likely, brake fluid or an axle seal will do it 90% of the time. Bob
