Technical 1 wire alternator assistance needed....
Discussion in 'The Hokey Ass Message Board' started by Stonehenge, Feb 6, 2021.
  1. Stonehenge
    Stonehenge
    from Colorado
    Hello guys.
    I need a bit of help on the following.
    1940 Ford
    Car is 12 volt, negative ground.
    I would like to install 12 volt, self-regulated 1 wire alternator with correct shaft for large flathead belt pulley.
    1 What is the part number for an appropriate 65 amp internally regulated (1) wire alternator to fit the sling-shot style bracket for the flathead?
    2 What is the proper wiring set up for this application? (not using stock regulator).
    3 Would like to work with someone who has done this with good results.
    4 Results should be an alternator that charges around 13.8 with a new battery +/-.
  2. Mr48chev
    Any 10 SI frame alternator will fit that bracket. One wire alternators are generic except for the clocking of the plug. Most you re-clock to your needs if the plug is in the wrong position.
    What you are really hunting for is a wide belt pulley that fits on a 10 Si alternator that you can stick on one. That way you aren't paying a premium for an "OMG this is a special flathead one wire alternator".
    Side note, if you don't have to have a chrome case you can walk into a Ford New Holland tractor dealer and get a one wire alternator for a 9 N tractor as that was what one wire alternators were designed for in the first place. They were farm equipment conversion alternators long before they got popular for hot rods.
    NEW 1 WIRE 12V 63AMP ALTERNATOR FITS FORD 2N 9N TRACTORS REPLACES GENS AKT0001 | eBay
  3. MeanGene427
    MeanGene427
    from Napa
    yesterdaystractors.com has them with the wide pulleys for the early Ford tractors, I put one on my 8N and another on my 850, IIRC about $85. Nice thing too, they charge from idle, don't have to rev it up
    HemiDeuce and Bob Lowry like this.
  4. Stonehenge
    Stonehenge
    from Colorado
    This is very helpful. Thank you.
  5. stillrunners
    stillrunners
    from dallas
    Cool info guys - thanks !
  6. dirt t
    dirt t
    Good , no great information.
    Thank you
