10-spline input shaft sizes ????
Discussion in 'The Hokey Ass Message Board' started by Retired, Feb 27, 2009.
  1. Retired
    Retired
    I'm trying to find out what is the outside diameter of the spline on Chevy 10-spline transmission shafts?
    Also what is the width of the splines?
    Are all Chevy 10-spline input shafts the same diameter and width?
    Does anyone know what the diameter and width is on the 10-spline input shaft used in the 1960 Corvair?
    I need a 10-spline shaft that is about 1.060 outside diameter with about .160 wide splines and I don't know what to look for.
    <style></style>Any help would be greatly appreciated. Thanks .. Ray
  2. brokenspoke
    brokenspoke
    What are you trying to do?
  3. HR Classic Cars
    HR Classic Cars
    from Wylie, TX
    I think most (if not all) early chevy input shafts, at least around the 1960s are 1 1/8" (1.125") in diameter, but they are all 10 spline.
    Knowing what you are trying to achieve will make answering your question a lot easier.
  4. JohnEvans
    JohnEvans
    from Phoenix AZ
    Some 50s-60s Fords had a 10 spline 1&1/16th [1.062 nom.] input shaft on there trans.
  5. Retired
    Retired
    I put an 38 Chevy transmission on the back of my model T engine as an auxiliary transmission.
    The drive shaft U-joint on the auxiliary trans is for a 10-spline shaft.
    I need a 10-spline shaft that I can cut off and adapt to the front of the model T driveshaft so it will fit into the U-joint.
    I've been looking for a 30's Chevy drive shaft tube but haven't found one yet and wondered if I could use some other 10-spline shaft.
  6. 53sled
    53sled
    from KCMO
    even a 1988 chevy truck can share that 10 spline pattern, very common. I mated a sag 4 speed to a stock 88 chevy 11" clutch. get a clutch pilot tool, cheap, and try it out before you go digging at the s**** yard.
