Technical 11/16-18 castle nuts???
Discussion in 'Traditional Hot Rods' started by 65standard, Sep 3, 2020.
  1. Maybe find a thick nut and cut the top into a castle style. Front axle nut (new cars stuff)?, strut rod bolt, maybe even a lug nut. Have to check sizes.
  2. How about drilling plain nuts for a lock wire or pin?
    Sent from my moto g(8) power using The H.A.M.B. mobile app
    rbrewer likes this.
  3. Happydaze
    Happydaze
    Aren't there concerns over the suitability (quality) of those spring perches being used in that style of application? The consensus seems to be to use originals.
    Chris
  4. brading
    brading
    Found a company over here that lists them,but no price. If you would like me to find out a price let me know.
  5. earlymopar
    earlymopar
    Yep. This is what I had to do with mine. I found grade 8 bolts and then drilled them.
  6. 65standard
    65standard
    4AC8EDC0-87C2-40BF-A3E2-86E63261F407.jpeg 358ED2CB-BBE7-4299-91CF-371A9D21E491.jpeg 485C9E5A-7A4A-4CB2-B587-462E15E4AE9A.jpeg
    Thank you Phil for the 11/16-18 nuts. They came in today. I really appreciate your generosity.
    Thank you Fordors for the offer on your tap. I have one already
    And yes I will add a panhard bar because I’m staying with the cross steering like the ‘41 ford had. Using a Vega steering box and will probably add a steering stabilizer
    rbrewer and Stogy like this.
  7. 65standard
    65standard
    Custom 11/16-18 Castle nuts. Just need to drill the cotter pin hole and trim a little off the end. Just want 2 to 3 threads exposed
    Stogy, egads, rbrewer and 4 others like this.
  8. pprather
    pprather
    Custom castle nut. Good job!
    Phil
    Stogy, rbrewer and continentaljohn like this.
  9. rjgideon
    rjgideon
    Tony, how much room between your spring and tie rod? I have a very similar front suspension and I've got maybe 3/4". I'm still in build phase with the full weight of engine and trans and body on there. I haven't yet messed with the steering arms for ackerman yet, so I could move them down a little if needed when that time comes. My spindles are 40 Ford with the steering arms still in place.
  10. 65standard
    65standard
    1” is as tight as it will ever be on mine. That’s with the shackle fully vertical. I’m using ‘41 Ford spindles.
    rjgideon likes this.
  11. rbrewer likes this.
  12. DDDenny
    Not sure why they show an 11/16" castle nut in their ***le, Grainger only shows the two 7/16" nuts as options, and ònly in pkgs of 710, no actual item number for 11/16.
  13. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    I'm thinking that Grainger is showing the hex size. Somebody needs to clue the web guy in.
    RICH B likes this.
  14. Fordors
    Fordors
    Or just a web geek with no mechanical knowledge or ap***ude.
    continentaljohn likes this.
  15. 65standard
    65standard
    A3C679F5-DCBB-4423-8A4C-A357BA4E4C89.jpeg EFFE42A2-22B4-45F3-865C-0C18853EFE56.jpeg 43F45CC1-67F1-45E0-A55D-80E15A1DE138.jpeg E3CACFB4-EB60-482E-85C8-3AB3544F80E2.jpeg 37BF9FF5-0FBA-4F36-820D-789FD0BB8E75.jpeg Thanks everyone for the help. Front suspension complete, now for the steering and shocks.
    Stogy, egads, rbrewer and 5 others like this.
  16. Andy
    Andy
    I was all over the road without a panhard rod. I had the shackles at the 45* angle.
  17. Bert Kollar
    Bert Kollar
    If there was a little market for these I can get them made but my pal would probably want to make a 100 or so to make it worth while
  18. clem
    clem
    it would weaken the nut as well as decreasing the amount of thread in contact with the bolt, ( which is probably why the castle nuts are generally longer ).
    Illustrious Hector likes this.
  19. FYI, a great source of USA made taps and dies is " Wholesale Tool ". I just recently bought a 12-28 tap, $ 2.57,and a 3/8-32 tap, $ 7.14, from them to use on Stromberg carburetors. In the past, I also bought an 11/16-18 tap and die to clean up the threads on 1935-1936 Ford truck and p***enger car headlights, as well as 1937-1941 Ford truck headlights. As far as I am concerned, they are the source for taps and dies. A great on-line catalog, as well as knowledgeable sales people when you call looking for the odd-ball sizes, and great service, with same day shipping if you call before 1:00 PM, too.
    Stogy and Algoma56 like this.
  20. Thanks for the Wholesale Tool tip. I checked, and they ship to Canada, so maybe time to re-stock.
    Stogy likes this.
  21. pprather
    pprather
    @65standard , any updates on this project since you widened the wheels?
    Stogy likes this.
  22. 65standard
    65standard
    Hey Phil. I haven’t worked on the ‘32 in a few months. I got frustrated with the wide 5 wheels after they came back from powder coating. They look horrible with fish eyes everywhere. I’m probably going to stick with the 1940 wheels.
    I’ve been saving up for the brookville body pieces.
    pprather likes this.
  23. pprather
    pprather
  24. Illustrious Hector
    Illustrious Hector
    Help me out what is the reason for the threads? simply to remove the perch? I have a similar set-up on my car, spring behind the axle. Mine is welded through the wish bone, I used the old perch bolts cut off, but it looks upside down to what you have. My shackles sit around 43 degrees.
  25. 65standard
    65standard
    I wanted to fine tune the perch mount to be perfectly true with the spring at ride height, then tighten the nut and lock it in. ECEA86E9-7EDE-4911-B064-C6D1CD2A20EF.jpeg
    Haven Hills Auto Club likes this.
