Technical .
Discussion in 'Traditional Hot Rods' started by thomasanonymous, May 27, 2018.
  1. sunbeam
    sunbeam
    There were a lot of 1/8 over 221s in the day. don't worry about .060.
  2. Nobey
    Nobey
    If you don't cut the ridge, and you beat the piston out, something is going to break. That something might
    be you block. Flatheads are sometimes fragile in this area. I saw a guy do this, and cracked one cylinder, and
    broke the top out of another. This was after I advised him to first cut the ridge. I saw another guy weld nuts
    on the studs, and use an impact gun to move the studs. he broke a big chunk out of the block. If you don't
    believe me, ask the top flathead builders on here. Like Dale, or Tardel....
    Not trying to be a smart *** here, just trying to save you some grief......
    Blues4U likes this.
  3. Petejoe
    Petejoe
    Why take the piston out at the top?
    Just dis***emble the rod and push it down.
    Plenty of room for that.
  4. solidaxle
    solidaxle
    from Upstate,NY
    Thomas stated he was going to take it to a builder. I would suggest take the motor out whole and let the builder take it apart.
  5. Nobey
    Nobey
    Only four pistons will come out the bottom, #1 #3 #5 & #8 you,re in luck with #5, but you'll
    have to pull the crank!
  6. Ebbsspeed
    Ebbsspeed
    It's also a "pull rod" during the Intake stroke. On the Compression, Combustion and Exhaust strokes it is pushing on either the piston or the crank.
    I apologize for being a smart ***. I was born this way.....
    Petejoe likes this.
  7. Blues4U
    Blues4U
    from So Cal
    :D :D
  8. Petejoe
    Petejoe
    Stay away from champions.
    You may be ok for now,
    But at least you can save some money for a rebuild.
    It’ll happen sooner than you think.
    There’s a reason why your plugs are fouling ya know.
  9. Atwater Mike
    Atwater Mike
    glad youze guyz found it...
  10. solidaxle
    solidaxle
    from Upstate,NY
  11. Condensers gone bad"mine had the same Symptoms Easy fix
