12 bolt electrical system... do I need a 12 bolt rear end?
Discussion in 'The Hokey Ass Message Board' started by oilslinger53, Dec 19, 2008.
  1. Boltinators ain't traditional, dadgummitt! But Merry Christmas to y'all still is!
    All of you and your families have a good Christmas! Now back to the 12 bolt Christmas lights on the tree. They have twelve points and all I have is a 30 point, I mean pack. Wait, it that buck, deer, beer...............?
  2. 40Standard
    40Standard
    from Indy
    and don't forget the 12 pack
  3. drock6570
    drock6570
    can you run 110 household bolts?
  4. chris55
    chris55
    You can mix 12 bolt with 6 bolt, if you use stainless. Unless your south of the Equator, than the polarity of the bolts goes counter clockwise.
  5. thebrassnuckles
    thebrassnuckles
    you dont wanna attract possums, they will chew right through a 12 bolt system, if you stick with the 6 bolt they cant chew through the wiring. its cause the 6 bolts carry a larger hamperage. possums hate hampers, so they stay away from the 6 bolts.
    9 bolts may attract the young ladies, but also the beavers. the 9 bolt beavers will chew right through you wallet.
  6. **** I didnt need to read that after only 1 ****tail!! MERRY CHRISTMAS
  7. eaglebeak
    eaglebeak
    If he does go through with all the 6 bolt to 12 bolt conversions, 6 cylinder to 12 cylinder, wheel nuts, etc.....will his 6 p***enger car now hold 12 p***engers?
    If so, I would like more information on how to do it.
    Also, if I rub some 6 bolt grease on my 6" weenie, will it grow to 12"?
    My girlfriend wants to know.....
  8. Pscott
    Pscott
    :mad:dammit why does every thread end up as 6 bolt vs 12 bolt? the 6 bolt crowd will never be converted and vice versa!:mad:
    Merry Christmas you filthy animals
  9. Tony Ray
    Tony Ray
    all these bolts and I still havent figured out what to use on them..standard,metric..or are they whitworth??
  10. thebrassnuckles
    thebrassnuckles
    they are actually numetrical bolt i think, i may be wrong, i lost count at 354 bolts. now i have to recount the bolts.
  11. Don't get your Roman nut sizes confused with your Your-a-Peein nut sizes.
    Like a Roman 3/4" would be cl***ified as a III/IV" and a Your-a-Peein would be cl***ified as a 1.905 , which is a easy to confuse with a 1.905 hector or a 1.8823 rodriguez.
  12. oilslinger53
    oilslinger53
    from covina CA
    so, b=CxG so i could keep my motor and add another small gas tank right?
  13. BuiltFerComfort
    BuiltFerComfort
    Hey, it's good to see I'm not the only one confused by this stuff. Maybe you guys can answer some questions I've been thinking to ask.
    I put a Ford 8.8 rear end in my car, does that mean I need two v8 motors now? Or do I need a V 8.8? The V stands for volts, right? So I have a fractional voltage motor?
    And my driveshaft, it just looks like a long pipe, not at all like my driver or my shaft. Did I get shafted on that?
    And I went downtown to the speed shop and told them I needed a ******, and they sent me to this bar with a bunch of cross-dressers. I nearly got into a fight with one, he/she/it thought a hot rod was something quite different - he kept looking at my belt buckle...
  14. chevy57dude
    chevy57dude
    Ya gotta watch out for fine thread bolts no matter what! Since the fine threads take more turns to tighten,they can build up more inductive boltage due to static. Therefore a fine thread 6 bolt system can actually produce 10 bolts! Also remember to purchase an adaptor before traveling in europe,their systems are different.
  15. not possible, too much boltage required. i hear some one is working on combination to make it smell like that aerosol spray they show on t.v. so that the lovely young ladies are naked already when they show up. bonus!
  16. JohnEvans
    JohnEvans
    from Phoenix AZ
    Oh ****!!! Toooooooo funny !!
  17. Pscott
    Pscott
    As usual, you guys are ignoring the O.P.'s question:
    I'm surprised that no one has stated the obvious answer which is- this is why the torque convertor was invented, to convert the 12 bolts from one end to 6 bolts at the other.:D
  18. chainsaw
    chainsaw
    I picked a hell of a day to sober up.
  19. I've got a 6 pack and a box of nuts'n bolts,will that help?
  20. Pack level is way to low to allow good thinking. You must adjust to allow fpr a higher level of boltage!
  21. fastrichy
    fastrichy
    from ne ohio
    if you find previously lost bolts around the shop,can you get electricuted by the stray boltage?
  22. HOLLYWOOD GRAHAM
    HOLLYWOOD GRAHAM
    from Ojai,Ca
    Fool'em all and add 1 more bolt for a 13 bolt...
  23. no,thats static electicity,not enough bolts to hurt ya.
  24. RichG
    RichG
    Looks like I picked a bad day to quit sniffin' glue.
    But seriously, converting 6 bolts to 12? Doncha know, "ya can't get there from here".
    Tear it all out and start over. Really. Tear it all out, sit between the frame rails and scream "banana boat quickies make me squishy".
    Merry Christmas :)
  25. EnglishBob
    EnglishBob
    Mine's boltless so do i have to 'charge it' on my card?
  26. Mopar Mama
    Mopar Mama
    from Boise, ID
    Oh ****! That's a real kustom touch!
  27. JEPPA
    JEPPA
    As long as it is divisible by 6, your fine. Merry Christmas.
  28. I'm putting up my Festivus pole and writing my list of grievances as we speak! To all who would challenge me in the Feats of Strength, be ware.
  29. silversink
    silversink
    I cant believe you guys have forgot to change to 12 bolt you also have to change the from NEG bolarity to POS bolarity
  30. remember when running the 6 bolt stolenoid from a 12 bolt circuit you need to double the current by way of a light transfer quadrupler. darth vader may have some NOS, hook him up via deathstar.****impissed
