12 bolt truck axle?
Discussion in 'The Hokey Ass Message Board' started by cktasto, Oct 31, 2009.
  1. cktasto
    cktasto
    I'm looking for a rear axle for my 55' g***er and I keep seeing these posi rear ends out of 4x4s and trucks for pretty cheap...anything wrong with going that way? I dont have a clue about the width but if that works out seems like it'd be a good way to go.
    Charlie
  2. slammed49
    slammed49
    Most of those are 6 lug wheels...you can swap just the shafts for the 2 wheel drive 12 bolt shafts but you still get a 5x5 bolt pattern...if interested PM me,my neighbor has a Dana 60 5 lug fron a Mopar...HD and good price
  3. squirrel
    the 5 lug axles were used starting in 71, and the rearend width was changed in 70, so you can only use the 5 lug axles on 70-81 rearends.
    Width would be ok if you radius the wheelweels :)
    If your car has some serious hp you'll want to make sure the rearend is in good shape, they tend to crack the pinion gear teeth
  4. TheNovaMan
    TheNovaMan
    from Michigan
    The problem with truck 12-bolts is that they have the same pinion diameter as an 8.2" 10-bolt (1.438" vs. 1.625" for a car 12-bolt or 8.5" 10-bolt)
    Edit: wouldn't a 57-64 Olds/Pontiac rear be more period-correct?
  5. cktasto
    cktasto
    hey slammed, sent you a pM thanks!
  6. cktasto
    cktasto
    Hi pete, I have an Olds single leg rear end in it now but mythinking is it'll be pretty pricey to change the carrier to posi...do you agree?
  7. cktasto
    cktasto
    Hi jim, the car wont see the track...just a street rod, but I suspect I'll be somewhere in the 450-550 hp range.
    so the trucks went to 5 lug in 70? and then got wider in 71?
    I am going to be radiusing the wheel wells (its a 55 g***er afterall!) so I guess I'm OK with a truck rear end? Do you know off hand the width of those rear ends?
  8. squirrel
    if it were me I'd keep the Olds in it. Width on the 70s truck rears is about 63" flange to flange I think.
  9. TheNovaMan
    TheNovaMan
    from Michigan
    Most likely. I don't even know if anyone in the aftermarket makes a limited slip or locker for it. Mark Williams has a spool, but it's $316, and you probably don't want a spool on a street car.
  10. Double Caddy
    Double Caddy
    from virginia
    Chevy 12 bolt truck rear end are 64 inches wide . I am swapping one out into my 53 Caddy right now. Its an even swap for me.
