Technical 12 V coil test?
Discussion in 'Traditional Hot Rods' started by TudorTony, Nov 18, 2016.
  1. TudorTony
    TudorTony
    from NJ
    '49 Merc Flatty tweaked, running a 12V system & electronic distributor. Runs idles fine in nuertral but breaks up under load. Typically thinking coil? Checked resistance on primary and secondary at 1.5 Ohms & 8500 Ohms. Internet says 1.5 on primary good but vague on secondary. Some say 8000 to 12000 ok others say under 11000 no good? what's concensus here?
  2. OzyRodder
    OzyRodder
  3. Dean Lowe
    Dean Lowe
    Yup, condenser.
  4. flatjack
    flatjack
    Notice he said electronic distributor. They do not use a conventional condenser.
  5. Yeah, 8.5K ohms seems low. I'd expect to see 12 to 15K ohms for a good output.
  6. Petejoe
    Petejoe
    from Zoar, Ohio
  7. Lisle makes a coil tester , part # 50660
  8. tedley
    tedley
    from canada
    does the electronic require a resistor before coil to drop it down to 9 or a a straight 12 volt.
  9. TudorTony
    TudorTony
    from NJ
    Not using ballast per, note from Mallory on this distributor indicating distributor requires 1.4 ohms of coil resistance, my coil is delivering 1.5 Ohms as previously indicated. Also specifically states if using a coil with less than 1.4 ohms, you must use a ballast resistor that will achieve the required 1.4 ohm total resistance. As the secondary coil resistance seemed a bit low got new Pertronix 40001 coil and that seems to have fixws the problem.
    Thx
