Customs 12 V,
Discussion in 'The Hokey Ass Message Board' started by Dangerousdan, Jun 8, 2021.
  1. Dangerousdan
    Dangerousdan
    from Arizona
    Looking for suggestions on AC /Alternator brackets that work on the 49' 53 ' flathead. With a 12V system
    At this time I have 2x2's with the narrow belt W/Ps. thanks
  2. 210superair
    210superair
    from Michigan
    My ac is where the genny was, and you can see my bracket here, though I can't tell you where to buy one....
    Flathead Dave likes this.
  3. BJR
    BJR
    Can you afford to loose about 10 HP on a flathead? That's about 10%.
  4. Jack E/NJ
    Jack E/NJ
    from NJ
    Nope. 60+ amps is only about 1hp on 12v. 1%.
  5. Dangerousdan
    Dangerousdan
    from Arizona
    BJR, Thanks for your input. Running AC will take away from a source that is already low? But living in an area where AC is needed six months ayear is questionable.
  6. BJR
    BJR
    Most of the sites I have looked at say an ac uses about 10 HP.
  7. Jack E/NJ
    Jack E/NJ
    from NJ
    Sorry, I was referring to alternator load. Agree on AC load. 10HP sounds about right to me.
  8. Nitroholic
    Nitroholic
    from SoCal
  9. Jack E/NJ
    Jack E/NJ
    from NJ
    Hardly any belt wrap around those alt pulleys with air.
  10. Mr48chev
    I can't figure out why you guys make such a big deal out of what few horsepower it takes to run a small Sanden Air compressor. If he needs what little extra power the AC takes he can always turn the AC off.
    That shoebox weights about 500 lbs more than my 130 hp Prism GSI did and while you knew the ac compressor had kicked in it didn't drag that little banger down much.
    These new compressors don't take near the power that those Delco A-6 units did. With one of those he might have an issue.
  11. Dangerousdan
    Dangerousdan
    from Arizona
    Thanks for all the input. I think I was hoping that one of us can recommend a manufacture making the Alt/ Ac brackets.
  12. birdman1
    birdman1
    nice looking motor.
  13. Nitroholic
    Nitroholic
    from SoCal
    Try the link in post #8.
