12 volt conversion question
Discussion in 'The Hokey Ass Message Board' started by Bud37, Nov 9, 2009.
  1. Bud37
    Bud37
    from Danbury CT
    Where do I put the 12 volt to 6 reducer for the heater motor? In the wire going to the heater motor, or in the wire going to the heater switch?
  2. 51 MERC-CT
    51 MERC-CT
    ***uming that the switch is variable speed, before the switch.
  3. Bud37
    Bud37
    from Danbury CT
    Thank You
  4. MBL
    MBL
    It shouldn't matter because the current draw of the motor will determine the kind of stress the switch sees. Keep in mind that the 6V switch is able to handle more amperage than a 12V counter part....so theoretically, you should be way fine.
    Tim
    MBL
