1952-59 Ford 12 Volt conversion
Discussion in 'Off Topic Hot Rods & Customs' started by greaser 35, Jun 21, 2021.
  1. greaser 35
    greaser 35
    from FRANCE
    For 1 piece purchased it is necessary to count double in shipping costs/ tax, so the account is quickly done!
  2. JeffB2
    JeffB2
    from Phoenix,AZ
  3. greaser 35
    greaser 35
    from FRANCE
    https://www.ebay.com/itm/174095008820 New Alternator Chrome 10SI 100 AMP ONE WIRE BBC SBC CHEVY High Output 7127-SE : Is this alternator going well for my 12V run?? https://www.ebay.com/itm/174665212538 New Regulator Gen For Chevrolet Models 3.9 12V 27-31 AMP 1118935 1118936 1118945 : and do I need this regulator where then I don’t need it?? Thank soo much for a lost french guy !!
  4. TomDobbs
    TomDobbs
    The alternator you are considering is 1 wire and internally regulated, so you don't need an external regulator.
  5. JeffB2
    JeffB2
    from Phoenix,AZ
    With a One Wire Alternator the regulator is built in, you DO NOT need an external regulator that also eliminates some external wire clutter the hook up with a 100 Amp is a 6 gauge cable from the alternator to the Positive battery post only.
  6. greaser 35
    greaser 35
    from FRANCE
    Great !!! Thank you !!!!!
  7. jimmy six
    jimmy six
    Some single wire PowerMaster Alternators also have a post on the back to use for the i-did-it factory light by attaching it to the original wiring at the regulator.
  8. greaser 35
    greaser 35
    from FRANCE
    To connect my tachometer I look for where is the terminal after contact on the ignition switch , which is it? it is ACC or BAT or IGN or the center of the ignition switch ? Thank you !!
  9. jimmy six
    jimmy six
    Sorry to back to this post but yes sometimes you do! Some of us know typical word differences but “wire beam” was a new one for me. Good luck with your “foreign car”…
