Technical 12 volt OD solenoid in a 6volt car
Discussion in 'The Hokey Ass Message Board' started by xcavator, Mar 25, 2014.
  1. xcavator
    xcavator
    I have a T86 top load trans I want to put in my 53 ford The car is 6volt Ibeleive the solenoid is 12v . Any input on this problem would be great. Thanks for any help
  2. Erics53
    Erics53
    from Ohio
    Well.... You could use a 6 volt relay to switch in a separate 12 volt battery. Or you could try and build this simple circuit.
  3. 302GMC
    302GMC
    from Idaho
    Use a pre-'55 Ford or Merc solenoid.
  4. Mike51Merc
    Mike51Merc
    I'd bench test it. If it fails, plan on spending about $200 for a new/rebuilt 6V solenoid.
