Customs 12 Volt Starter for 1954 Chevy 235
Discussion in 'The Hokey Ass Message Board' started by worthop, Sep 22, 2015.
  1. worthop
    worthop
    need a part number or range of years/models I can get one from. Converted to 12 volt..... Thanks
  2. Go to any auto electric shop and they can do it for you real easily. If you have a 235, anything '55 and up with the same transmission, etc should work well.
    I stopped pissing around with store-bought starters decades ago and a local shop is the way I roll.
  3. Rex_A_Lott
    Rex_A_Lott
    I have not done it with your exact starter, but I have converted both a Model A and a '51 Ford flathead V8 to 12V and I didnt do anything to the starter but hook the 12V to it. It also doesnt matter about the polarity, it will spin the same direction either way. Good Luck!
  4. Hnstray
    Hnstray
    from Quincy, IL
    Rex is correct..........a 6 volt starter that is otherwise in good condition, will operate on 12 volts for years in normal operation. Normal operation meaning that your engine doesn't have other issues and starts readily when cranked.
    If you prefer, you can have a 6 volt starter converted to 12 volt specs by an electrical shop, as suggested above by bodss396.........it involves, mostly, changing the field coils.
    Ray
  5. I'm funny about auto electrics. I take the piece in question to the pros, tell them what I want, pay the man what he wants and we're both happy. It never hurts to have a unknown item gone over, unless you enjoy being stuck on a cold and rainy night somewhere.
    Hnstray likes this.
  6. F-ONE
    F-ONE
    from Alabama
    Yep.
  7. 54fierro
    54fierro
    from san diego
  8. worthop
    worthop
    6 volt solenoid should be good as well? with a 12 volt conversion?
  9. You don't need one but if you must '57/'58 chevy will work.
  10. Cosmo49
    Cosmo49
    I ran a 6 v starter on 12v for 17 years on my dd/only vehicle.
  11. 270dodge
    270dodge
    from Ohio
    Yep that 6 volt starter will be a "high speed" starter. Just do not use for extended times.
    You'll like it.
  12. And the difference between a 1954 235 and a 1955 235 is...........?..(aside from 6v/12v)
  13. Hnstray
    Hnstray
    from Quincy, IL
    I believe there is a difference in the number of flywheel and starter drive teeth, beginning in'55 with the 12 volt units. The flywheel and starter drives must be used in matched pairs, not mixed.
    Ray
