History ...
Discussion in 'The Hokey Ass Message Board' started by sgtlethargic, Jan 4, 2022.
  1. Big Dad
    Big Dad
    Henry Ford spec'd a certain wood, size , etc on parts being shipped in crates so he could re-use the wood for parts of his cars .. the left over he used to make charcoal briquets to make camp fires to cook and sold that to the public
  2. 210superair
    210superair
    from Michigan
    There's usually only one reason a company does anything in my experience: money.
    On a side note, I graduated in 1994, with a few years of wood shop cl***, and a pretty solid woodworking ability. They don't even have that option anymore. Kinda sad. Shop cl*** as well. And they wonder why later generations are mostly lazy and useless.... They didn't teach them anything cool and fun!
  3. stubbsrodandcustom
    stubbsrodandcustom
    from Spring tx
    Nail on head, more ways than one...
  4. finn
    finn
    Ford was much more vertically integrated than GM all the way through the fifties. Ford owned vast forest lands, sawmills, factories in Upper Michigan to make wood bodies and lumber for shipping crates, body supports and floorboards, iron ore mines in Minnesota and Upper Michigan, ore boats, steel mills, coal mines, and rubber plantations in South America.
    Ford bought bodies from Briggs, Murray, and Budd. GM used Fischer, which was eventually their in house brand., and was slower to convert to full steel bodies. The answer as to why probably has to do with workforce skills and what the factories were set up to produce, with Fischer being a legacy coach builder.
    Stogy likes this.
  5. alanp561
    alanp561
    What's the matter, your local welding shop didn't have low-oak welding rod? ;)
  6. squirrel
    uh...it's Fisher. Not Fischer.
  7. lippy
    lippy
    from Ks
    I'm not so sure I understand all I know about this. And I know I'm not sure I want to.
  8. 31Apickup
    31Apickup
    It is all related to the evolution of the industry, early cars the sheet metal was stamped in multiple panels due to the size of the presses. They could build the wood framework, then attach the panels as they came in. As they developed larger presses and they stated added more steel reinforcement. I’m sure it also had to do with the skilled trades doing the work, you had skilled woodworkers who were slowly being replaced or becoming obsolete. Fisher body was one of the longest holdouts.
    Stogy likes this.
  9. Yup, hence the term COACHBUILDERS which we still use today for this specialized trade.
  10. goldmountain
    goldmountain
    As to later wood usage, my '64 Barracuda had a plywood panel between the cabin and the trunk.
    Stogy likes this.
  11. lippy
    lippy
    from Ks
    Does a matchbook cover folded under an 8-track qualify as wood?:)
  12. finn
    finn
    Apple spelling, I guess.
    Were Apple products ever framed with Apple wood?
  13. sunbeam
    sunbeam
    My guess like most car companies COST. Like Ford in the 60s when they but plugs in front end parts instead of grease jerks.
  14. gimpyshotrods
    gimpyshotrods
    One of their first prototypes was built in a wood case.
    Tman likes this.
  15. Yup ^^^^^
    Interesting thought. Last I checked Morgan (an English sports car) was still building bodies with a wooden frame work.
  16. I think the 3 wheelers are?
  17. Do they still build a 3 wheeler? Dad always said that they are just a motorcycle with a body. LOL
    They have not really changed the body in about 60 years. The wood makes them really easy to build, other than the fenders and snout they are basically just flat steel. A cabinet makers car.
    Tman likes this.
  18. 31 B'ville
    31 B'ville
    from SE Pa
    One story I had read somewhere about GM’s use of structural wood in their car bodies was that they got over 30,000 acres of woodland when they acquired Fisher Body and were determined not to let it go to waste. Being that they had the craftsmen and the the wood, it probably was more of an economic decision than a technological one.
    Stogy likes this.
  19. gene-koning
    gene-koning
    They used to say that pound for pound, wood was 4 times stronger then metal. Thin flat sheet metal needs to have bends to have strength. In the early days they had the ability to make bends on small pieces of metal, but not pieces large enough for body structure, so for structural strength, the metal had to be welded together.
    They could build a stronger large structure out of wood, then add the extra strength of sheet metal with a few bends in it, and nail that steel to the wood. It took a few years before the metal technology caught up with the wood technology of the early automotive days. I'm sure money also had an effect on the final outcome, plus the fact that metal can be produced a lot faster the wood can be produced. Gene
  20. Truckedup
    Truckedup
    In 1935 GM was the first with a steel turret top on cars....
    Tman and Stogy like this.
  21. Ford did not give up on using wood until 1951. ;)
    Last Of The Wood-Bodied Wagons
    Ford woody wagons up to 1948 were all wood from the cowl back, with the exception of the rear fenders. On 1949 to 1951 models, real wood attached to the steel body on the doors, sides and tailgate.
    Truck64 and Stogy like this.
  22. Greenblade
    Greenblade
    I've always wondered if it's practical to take an old wood frame bodied ford and replace the wood with metal. Doesn't seem like it'd be all that hard to do. My grandpa has one at his shop with all the wood rotting away, was thinking it'd make a great rod as long as I didn't have to replace wood with wood.
    Stogy likes this.
  23. gimpyshotrods
    gimpyshotrods
    Maybe.
    I did one '29 Chevy years ago.
    If I had to do it over, I would buy a wood kit, and 3D scan it.
    That way I could water jet cut out interlock pieces to duplicate the shape and strength of the wood.
    clem, Tman, Stogy and 1 other person like this.
  24. Stogy
    Stogy
    Well now there's a Chevy forest and a Ford forest whoda' thunk?...But hey it had to come from somewhere...I'll bet there's Historic Plaques at both of them...
    Budget36 likes this.
  25. PotvinV8
    PotvinV8
    I always thought it curious that they could stamp these intricate sheetmetal shapes and then the floorboards/toe kick was wood. Always seemed odd. Any reason as to why?
    Stogy likes this.
  26. The floorboard was called the floorboard for a reason, ...... boards are made of made of wood. It wood not sound correct to say , Let's put the pedal to the metal".
    HEY, that did not come out how I wanted it to. :eek: :mad:
    Stogy, hotrodjack33, Tman and 2 others like this.
  27. Budget36
    Budget36
    The Chevy trees grow faster, make better wood. All in all, a much better performing forest;)
  28. Automobile manufacturing grew and advanced faster than machines and tooling, plus, in the beginning and up to the mid '30s, labor was non-union and cheap! Ford hated labor, so he moved to automation before most (except for things that fell under his "it has worked for years, no need to change it" mantra). The Dodge Brothers were always looking toward the future and building better/safer products. DB was much more engineering oriented than the others.
    ProtoTypeDesignFlauz likes this.
  29. choptop40
    choptop40
    replaced the door wood in 36 Buick 3 window with kit from David Entler in 1992. back then was 500.00... cut slits in door perimeter to get the new wood in...then weld them ... doors closed like new after the installation with a precise adjustment of the turnbuckle.
    31 B'ville and alanp561 like this.
  30. alanp561
    alanp561
    Startd out as wood. Save the matchbook covers, they're becoming obsolete. How else are you going to set your points at .0015 in an emergency?
