125volt or six??
Discussion in 'The Hokey Ass Message Board' started by JasonSeaver, Nov 6, 2010.
  1. JasonSeaver
    JasonSeaver
    from detroit
    I have a 1950 chevy that i was told was converted i have a 12volt battery in it but its been running only on and off. im ruling out possible issues and would love a way to tell for sure if its been converted thanks
  2. REBEL43
    REBEL43
    from TENNESSEE
    check some of the light bulbs
  3. RDR
    RDR
    you say it's running on and off..?? Do you mean it quits running on you?....if so maybe it needs a resistor on the coil/ dist as points can burn up....also check to see if its' got a 12 gen or an alternator which is needed to charge a 12V batt
  4. themoose
    themoose
    Should be easy to tell if its converted.Check light bulbs,generator,coil,gauges would either have been changed or some sort of voltage regulator has been installed if they are reading correctly . Tell us exactly what the car is doing and I'm sure someone can help you>
  5. Deuce3wCpe
    Deuce3wCpe
    from New Jersey
    If it turns out it's been rewired for 125V you're gonna need an awful long extension cord to go anywhere !
    ....sorry couldn't resist :rolleyes:
  6. JasonSeaver
    JasonSeaver
    from detroit
    no light bulbs on it, it has a voltage regulator that looks original and reads 6volt, I cleaned carb and put it back on it started and then i set the idol turned it off and then when i started it agian the started just clicked.
  7. bobby_Socks
    bobby_Socks
    from ǑǃƕǑ
    They are talking about parking lights, dash lights. It almost sounds like someone stuck a 12 volt battery in your car and did not change anything over to 6 volts.
  8. Rebel 1
    Rebel 1
    I agree.
  9. tb33anda3rd
    tb33anda3rd
    battery was not being charged if it only has a six volt regulator. finish converting to 12 volt or put a new 6 volt battery in it.
  10. Mike51Merc
    Mike51Merc
    I'd go with 125 volt. Then you can run your blender to make frozen margaritas.
  11. tb33anda3rd
    tb33anda3rd
    120, 121 whatever it takes...
  12. Chebby belair
    Chebby belair
    from Australia
    At that voltage, you could engage the starter for overtaking!
  13. JasonSeaver
    JasonSeaver
    from detroit
    engage the starter? And that would explain why the new battery died after a day or so. If anyone knows a list of what i need to do to convert would appreciate the help.
