History ...
Discussion in 'The Hokey Ass Message Board' started by sgtlethargic, Jul 27, 2022.
  1. ...
  2. stuart in mn
    stuart in mn
    Looks like a cut down station wagon.
  3. Sancho
    Sancho
    Homemade Ranchero. My guess is a Fairlane wagon conversion.
    Factory Ranchero's were Falcon based then.
    Tow Truck Tom and jim32 like this.
  4. junkman8888
    junkman8888
    It looks like an Australian "Ute", except left hand drive, not to mention I don't believe they ever manufactured Fairlanes. My thoughts are I don't see where the side trim is "spliced" which is something you'd have to do if it started out as a four-door wagon, same with the trim on top of the bed sides, it also has that sheet-metal "wedge" that fills the space between the back of the door window frame and the back of the cab like the Falcon based "Ute", also, the back of the cab below the back gl*** looks like a manufactured piece, like what is used on the Ranchero. We need better pictures to be certain.
  5. Dick Stevens
    Dick Stevens
    It's a custom!
    NoelC likes this.
  6. Cut-down Fairlane wagon. Was a 4-dr as Ford didn't build a 2-dr in the wagon body, if you look closely you can see the joint in the trim. Still has the window winder for the tailgate gl***, wagon gas fill.
    Tow Truck Tom and chryslerfan55 like this.
  7. Sancho
    Sancho
    I think they moved the C-pillar forward to the back of the front door and the triangle panel just fills in the resulting space. That's why the c-pillars angle in so much at the bottom.
    The ranchero bed trim would also wrap around the corner to the tailgate.
    Compare to this similar view of a wagon:
  8. 34 5W Paul
    34 5W Paul
    from Fresno CA
    I'm with Sancho...
    He's a proven sharp eye, his catch on the McCormack Custom was spot on.
    I think the tailgate being taller than the quarters is a big clue as is the wagon rear window transplant. Cool start to a one of a kind ride.
    chryslerfan55 and Deuces like this.
  9. FrozenMerc
    FrozenMerc
    Old Funeral Flower car, maybe? Normally flower cars were made out of fullsize cars, but midgets and kids die too...
  10. oldiron 440
    oldiron 440
    It’s definitely a 63 4 door Fairlane wagon , Ford did have a two door Falcon wagon in 60 - 67.
  11. Note that the side rails are lower and 'kickup' a couple of inches at the back end to accommodate the higher tailgate.
    The wagon windows were lower than the tailgate.
    It looks like the tailgate gl*** was simply moved forward for the cab back window.
    34 5W Paul, chryslerfan55 and Deuces like this.
  12. The last year for a 2-dr wagon from Ford was '65, primarily because Ford also offered a sedan delivery most of those years ('52-65). Ford was the only manufacturer to continuously offer a 2-dr wagon from 1949 through 1965.
    Ford also built the only true 2-dr hardtop wagons (Mercury) '57-59. And before all the Nomad/Safari owners pipe up, those weren't true hardtops as they didn't have roll-down quarter windows.
  13. HOTRODPRIMER
    HOTRODPRIMER
    I believe it started life as a 63 Fairlane, the modifications that are visible is the top being removed, it is easy to fill in the back doors. HRP
  14. 61 Fairlane
    61 Fairlane
    They did use Fairlanes in 66 through 69
  15. Technically, it was '67-69. The Falcon switched to a shortened Fairlane platform in '66 except for the wagon (same body as the Fairlane wagon, now a 4-dr) but that used Falcon front sheetmetal, so the Ranchero was still a 'Falcon'. In '67 they switched to the Fairlane sheetmetal.
    chryslerfan55 and deucemac like this.
  16. oldiron 440
    oldiron 440
    That’s what I thought also but I found a sales brochure for the 66 Falcon listing a two door wagon, in 66 the Ranchero was based on the Falcon.
  17. There may have been a listing in a sales brochure, but to the best of my knowledge Ford never made another 2-dr wagon after '65 (unless you count the Pinto wagon later). Sometimes you'd find 'stuff' in the pre-release early brochures that ended up not making production.
  18. 61 Fairlane
    61 Fairlane
    Yup, My bad it was 67, not 66
