History ...
Discussion in 'The Hokey Ass Message Board' started by sgtlethargic, May 19, 2023.
  1. ...
    dana barlow likes this.
  2. Rickybop
    Rickybop
    '46-'48 Dodge Business Coupe
    But be aware that Plymouth sold some of their leftover 1948 models as 1949s. And they're ***led that way. Dodge may have done the same. Definitely a Dodge rather than a Plymouth, though.
    Tim, 41 GMC K-18 and sgtlethargic like this.
  3. Rickybop
    Rickybop
    You gonna buy it, maybe?
    As far as good hot rod projects, I'm convinced that that particular model and era you're showing could be one of the best deals going.
    - It's not such an early model that the ch***is needs major modifications.
    - It's not a later model with a curved windshield that's hard to replace or chop.
    - It's an old Mopar, which are often less expensive than other makes. But it's cool.
    - It's a business Coupe. Looks like a hot rod already.
    That one looks reasonably straight and solid.
    2Blue2 and 41 GMC K-18 like this.
  4. 41 GMC K-18
    41 GMC K-18
    That is just like the 47 Dodge, Model D-24 3 window business coupe, I sold to my good friend Matt Field
    AKA @Hitchhiker.
    @Cody Walls has a great build thread of one of those that is kick ***.
    This was my old car, which now belong's to Matt.
    guthriesmith, LOST ANGEL and ClarkH like this.
  5. carolina chevrolet
    carolina chevrolet
    No doubt that some of the valves are stuck. They had a flathead 6 cylinder and it's common for some of the valves to stick in an open position after sitting for a few years.
    I bought one like that from H.A.M.B. member a couple years ago. I worked on it a little, got it running and the brakes working. C562739E-CBF2-4629-B870-0E4D19338494.jpeg
  6. Tow Truck Tom
    Tow Truck Tom
    from Clayton DE
    Looks as if this could be a happy outcome.
    Best of luck
    41 GMC K-18 likes this.
  7. George
    George
    I used to have one. There are shock relocation and disc brake kits available. A rear sump 318 out of a van or pick up drops right in. The driver's side ex-man from the boxy early 70s Valiant/dart curles around the steering like it was made for it. Or a front clip from a Camaro, Chevelle, Cutl*** works nicely also.
  8. Rickybop
    Rickybop
    Yup, would make a good custom or a hot rod.
    Some people wouldn't consider this type of car as being good hot rod material... thinking it might be a bit heavy. But that car doesn't weigh any more than a first generation Camaro. There's more air than metal under those panels.
  9. Bearing Burner
    Bearing Burner
    from W. MA
    Fluid Drive refers to the semi automatic transmission
    firstinsteele likes this.
  10. Rickybop
    Rickybop
    Hood opens from the sides only.
    I'm not 100%, but I think Mopars of that era were the first to have a third tail light. And until recent decades, one of the only cars to have them. Not sure if it works with the brake light. That would kind of indicate intention as far as aesthetics versus safety concerns.
  11. CME1
    CME1
    I had one many years ago. I think it was a 1947 Dodge Coupe. Any way the third tail light did work with the brake light. I thought it was cool at the time.:rolleyes:
  12. buford_59
    buford_59
    The "third brake light" was thee brake light. The outside lights are running/park lights and turn signals. At least that's the way they are on my DeSoto. Any other Mopar guys want to chime in.
    BTW a late good friend used to do up a board to get the outboard lights to also be brake lights. He
    had a Chrysler T&C and a "Woody" Suburban.
    DoUg
  13. George
    George
    Yup! one brake light only. Makes a great 3rd brake light.
    41 GMC K-18 and SS327 like this.
  14. George
    George
    Plym & Dodge had 1 brake light, don't know about Chr & DeSoto.
    41 GMC K-18 and tmwracing like this.
  15. BamaMav
    BamaMav
    from Berry, AL
    They weren’t the only one with that arrangement. Lincoln also had the center brake light with the outer lights as turn and tails. With the later GM column, I was able to wire all three as brakes while keeping the outer as turn and tail.
  16. j hansen
    j hansen
    I think they look the same 1946 to early- 49.Mine is registered as a -49.
  17. Mr48chev
    There used to be a real nice one of those floating around the PNW about 30 years ago.
    Keeping it clean and simple body wise is the best way to go on those. I sure do like J Hansen's car though. Nice chop, some of the unneed chrome removed and simple frenched lights and it is a very nice custom.
    41 GMC K-18 and j hansen like this.
  18. gimpyshotrods
    gimpyshotrods
    I add sockets for dual-filament bulbs to the outboard lights on these, so they leave my shop with three brake lights.
    Rickybop and 41 GMC K-18 like this.
  19. George
    George
