12V Battery Restore?? Is this Bulls@%t
Discussion in 'The Hokey Ass Message Board' started by BBobb, Dec 7, 2009.
  1. BBobb
    BBobb
    I ran across this add
    Is this claim bullshit and or can it really be done.
    DON’T WASTE HUNDREDS OF DOLLARS TO REPLACE YOUR OLD BATTERIES.<o> ></o>
    You can fix and refurbish almost any Lead Acid Battery<o> </o>​
    WHEN YOU PURCHASE THE ITEM WE WILL SEND YOU THE Actual CHEMICAL YOU NEED TO FIX and REFURBISH YOUR LEAD ACID <st1>:place w:st="on">BATTERY</st1>:place>!!!! <o></o>
    Everybody else sends you just information.... a piece of paper for you to read. <o></o>
    This listing is for enough for 6-SIX batteries. <o></o>
    THE PRINCIPLE IS VERY SIMPLE: OVER TIME, SULFATE BUILDS UP ON THE PLATES INSIDE THE <st1>:place w:st="on">BATTERY</st1>:place>. MY METHOD WILL DISSOLVE THE SLUDGE ON YOUR <st1>:place w:st="on">BATTERY</st1>:place> PLATES AND ALLOW THEM TO TAKE A CHARGE AGAIN.
    <o> Don’t believe those who claim that their Grandfather invented the method or they did it themselves. It’s common chemistry knowledge that can be used in every day’s life. <o></o>
    </o>
    THIS PROCEDURE WILL WORK 98% OF THE TIME AND CAN BE DONE 3-5 TIMES ON MOST BATTERIES (EXCEPT THOSE THAT HAVE BEEN FROZEN)!!!<o> </o>
    THE METHOD IS VERY SIMPLE, AND THE PROCEDURE TAKES TEN MINUTES OR LESS!!! You don’t have to go to a dealer or pay a repair shop, YOU CAN DO IT YOURSELF!
    So, after the purchasing the item we will send you the DRY MIX and SIMPLE INSTRUCTIONS on how to refurbish your battery!!! <o></o>
    The Dry Mix, enough for 6 batteries, is non toxic and non-corrosive. The instructions on how to refurbish the battery will tell you how to do it and what materials to use for future!!<o> </o>
    TRUST ME, IT WORKS!
  2. kirby1374
    kirby1374
    I guess it "sounds" like it makes since.....I'm assuming then after the procedure you would put acid back in it?
    But if in doubt...."TRUST ME, IT WORKS"
    :D:D
  3. BBobb
    BBobb
    I have a least six batteries laying around and it would be cool has all heck to get them back up to charge
  4. How much does it cost to find out?
  5. There probably is some truth to the claim,,there is a battery shop here that sell new and reclaimed batterys.
    I don't have a clue as to what they do but the refurbished batterys work fine. HRP
  6. EnglishBob
    EnglishBob
    In England years ago there was a 'pill' you could drop into a battery that claimed to do the same thing--never worked for me
  7. i had a high school shop teacher claim that you could recondition a battery by completely discharging it and charge it with reverse polarity.that is supose to de-sulfate it. then discharge it and recharge with the correct polarity. i have no idea if that is possible or would work
    at the O'Reilly where i work they have a machine to test and recondition batteries...i should check into it
  8. BBobb
    BBobb
    Total of 15.00 with shipping
  9. 15.00 ? I'd give it a try
    pm me the info
  10. tommy
    tommy
    That's what they are banking on. IMHO Not enough money to create a furor if it doesn't work.
    Did the "pecker" extender pills work?
    Sorry but if it sounds too good to be true....
    I'm an admitted cynic and I have saved lots of money over the years. I have a buddy that goes for all the gimmics that come down the pike.
  11. 61bone
    61bone
    Holy shades of XP66, Batman.That's what was going around in the 60s to do the same thing. Had a cousin who worked for Exide. He said it would work well enough to get it out the door for a while.
    Never heard of viagra or cialis?
  12. Asphalt Outlaw Hero
    Asphalt Outlaw Hero
    from Dixie
    Usually batteries go dead because they short out along the plates at the bottom.On motorcycles,I use to rinse them out a fe wtimes and then fill with acid.
    It worked.....for a while.
  13. squirrel
    Have fun with that. I replace them every 5 yrs whether they need it or not.
  14. pitman
    pitman
    http://www.thebatteryclinic.co.nz/Batteries.html
    This was a useful site for some info on restoring. I think they are Kiwi's? (NZ)
    Plates becoming sulfated was the issue, as folks who knew about it explained, in the Materials Lab at school. Epitaxial growth of lead plate "spikes" were mentioned too, as causes of electrical shorts in cells.
    Don't think I'll part w/any coin on this one.
  15. 29nash
    29nash
    from colorado
    Two statements, gives me a hint. My new battery costs me less than 60 bucks at walmart, not hundreds........ Next, anytime somebody says TRUST ME, IT WORKS, I discount what they say out of hand................
  16. theamcguy
    theamcguy
    I believe the powder is EDTA. I have a bottle of it in the garage. It works but not all that great. What does work is pulse charging. If you have batteries you want to save invest in good pulse charger. They do work in almost all cases except if the plates are directly shorted. If the battery is just suffering from sulfate buildup then a pulse charger will work.
  17. Sounds like the s**t they hawked in the 1950's called VX-6;supposed to re-invigorate old batteries.Didn't work then;doubt it has improved over time.
    Note to self: DO NOT buy anything that has the letters X or Z in the product name.
  18. 49ratfink
    49ratfink
    if something like that worked someone on the HAMB would have already posted a thread about it.
    you can make up whatever shit you want and sell it to the uninformed. dietary suppliments, weight loss pills, weiner extender lotion, 100MPG carburetor gizmos.
    saw some battery operated belt people wear around thier waist that builds up your stomach muscles and burns fat at the same time. it must work, I saw it on TV.
  19. Demo Derby X-100
    Demo Derby X-100
    How's it with stains?
  20. Hot Rod Bob
    Hot Rod Bob
    from T-ville Ky
    Once the paste starts to fall out of the grid (or plates) you are going to need a NEW battery,the lead grid will not hold a charge without oxide paste.And paste gathering in the bottom will short out the battery.
  21. mikeco
    mikeco
    from virginia
    Can't say if it works,but not long ago I saw a morning news show & they said regular aspirin will do the same thing. They were listing all the things aspirin was good for.
  22. Jim Dieter
    Jim Dieter
    from Joliet
    Cant fix deterioration, I tried it for years at the junkyard growing up. Some would come back with a rinse and refill. But never for long. I'd put that 15 toward a new batttery.
  23. Billa212
    Billa212
    from Milwaukee
    The weiner extension lotion works, but must be applied by an attractive 18-21 year old female
  24. Hell yeah it works..
  25. RichG
    RichG
    Pass. It might, it might not, it would depend on the condition of the battery. Granted, it should work on a battery that is only "glossed" over, but there's more wear and tear on the battery than just that. Personally, I'd rather not worry about whether or not my battery is going to work...
  26. BBobb
    BBobb
    I think i will use the 15 bucks to buy a twelve pack
  27. RichG
    RichG
    ...then your battery WILL be lit!:p
  28. Hot Rod Bob
    Hot Rod Bob
    from T-ville Ky
    Now I could help ya with that!!! :D
  29. It says it works 98% of the time. Sure as hell I'd be the 2% it didn't work for ..
  30. ZZ-IRON
    ZZ-IRON
    from Minnesota
    For what it's worth :confused:
    heard how you can bring old batteries back to life on a golf cart forum 6 & 12 volt deep cycle batteries
    the guy said to dump the old acid out
    fill it with distilled water & charge it this will clear the plates ?
    the sulfate on plates will be dissolve easier in the distilled water then new acid
    many guys on the forum said it worked ?? a few didn't have any luck
    i was going to try it, when i paid $120 for six near new deep cycle batteries they sell for $120 or more for each battery
    figured this was easier then finding a place to dispose of the acid
