12v coil???
Discussion in 'The Hokey Ass Message Board' started by dogwalkin, Dec 10, 2025.
  1. dogwalkin
    dogwalkin
    from tn
    Is there a 12v you can use with points that doesn't require a resistor? Thanks in advance
  2. Rodney Dangercar
    Rodney Dangercar
    I don't know but you usually want the coil to get full voltage for starting and the resistance (wire or ballast) to be on the coil power when running so the coil don't overheat. I use a ballast set up in this way as a backup ignition (run MSD 6T normally).
    Sharpone likes this.
  3. squirrel
    yeah, it's called a 12v Universal Coil with Internal Resistor.
  4. dogwalkin
    dogwalkin
    from tn
    Ic14sb from napa looks right i think? Squirrel? Thanks
  5. squirrel
    I can't tell.
    Standard Motor Products UC15 is the right type, it says on it "12v no external resistor required"
    69fury and Sharpone like this.
  6. dogwalkin
    dogwalkin
    from tn
    Perfect. That crosses to the same coil.
    Sharpone and squirrel like this.
  7. mustangsix
    mustangsix
    Check the resistance. A coil for use with points without a resistor should be 3 ohms across the terminals.
    The term "12v" is a misnomer because a 1.5ohm (or even less) coil could also be used without a resistor on certain 12v systems.
    Sharpone, Crazy Steve and dogwalkin like this.
  8. jimmy six
    jimmy six
    I would NEVER use a resistor coil on a points system on a vehicle I used. I want the byp*** full volt system as the factory built. Battery voltage dips during startup and this means less to the coil using a built in resistor.
    The only exception is if your building a car where “hiding” every part and wiring is important to you in shows..
    Rodney Dangercar and Sharpone like this.
  9. squirrel
    Under what conditions does the coil really need full voltage to start the engine? I've had a few without the byp***, and they never had any issues...
    seb fontana and dogwalkin like this.
  10. Phil P
    Phil P
    I think up here in the great white north in the dead of winter in might be important.:rolleyes:
    Phil
  11. Moriarity
    Moriarity
    SUPER MODERATOR
    what kind of car is it?
  12. dogwalkin
    dogwalkin
    from tn
    1950 pontiac/1968 350 pontiac
    been using hei want to go back to my original points distributor.
  13. Moriarity
    Moriarity
    SUPER MODERATOR
    In that case I am going to move this to the main board and away from the off topic forum. I would use a 1.5 ohm coil and a 1.5 ohm ballast resistor if it were my car
  14. squirrel
    probably, but I thought you guys locked up all your old cars for the winter?
    TA DAD, Phil P, Sharpone and 4 others like this.
  15. Sharpone
    Sharpone
    Froze up and locked up can have the same meaning but not always. We will have a high of 5 or 6 F this weekend.
    Dan
    51504bat, squirrel and Budget36 like this.
  16. Phil P
    Phil P
    Your right I just heard the salt truck go by so nothing I care about is going out on the road.
    I was thinking more historically, in the early 70s when all I could afford was old cars at 30 below the egnition needed all the help it could get.
    I wired the egnition on my model A with the byp*** because I could not because it would really need it.
    Phil
  17. Budget36
    Budget36
    I now need to shut up and not complain.
    We’re knocking on 50 F for the highs the past week or so, and I bundle up like Ralphies little brother in “a Christmas story”. ;)
  18. 51504bat
    51504bat
    Bubba (RIP) recommended a Bosch Blue coil - Internal Resistor
    1oldtimer, dogwalkin and Sharpone like this.
  19. Rodney Dangercar
    Rodney Dangercar
    In AZ I can see why. Now try that on a good running carb'd engine with well used but still good ignition components (plugs especially) in 20 degree weather with thick oil and you might see the need. I have and you need every bit of power to fire up under those conditions. It ****s when it doesn't and you have to work on it in the cold.
    An internal resistor coil would work in a warmer climate, especially for garaged cars. But as a former mechanic I have always tried to do things the way they should be and not cut corners, but that's on me...lol. Others may see it differently.
  20. Buckster
    Buckster
    I was going to say-Bosch Blue Coil will work w/o a resistor.
    dogwalkin likes this.
  21. squirrel
    As a former mechanic, I've been having a lot of fun figuring out what I can get away with, and it turns out I can get away with an awful lot of shortcuts :)
  22. 51504bat
    51504bat
    And also picked up a few tricks from working in a junk yard, eh?:cool:
  23. Dang, Jim , I like that! My sentiments exactly.
    Ben
  24. Sharpone
    Sharpone
    Hoodlums:eek:
    Dan
  25. noboD
    noboD
    Any air cooled VW vendor will have them in stock.
  26. I have a few Blue coils and a GM coil that are internally resisted and a few for external resisted (1.5 vs 3.0). In fact I have a NOS GM coil (made in Japan) on the panel truck now, starts perfect hot or cold (47 on cold mornings).
    BTW be aware that not all blue coils are made the same. Older story but still applies.
    https://www.ratwell.com/technical/BlueCoil.html
  27. Yes agree on blue coils. Ones from Germany were top shelf and you pay for them. The south of the border ones resistance is all over the place. Need to check resistance before buying them.. Ones from South America were quite good. Been thru this with a beetle restoration. Hope this helps.
  28. LOL. PROUD ONES.
    Ben
