Technical 12v conversion
Discussion in 'The Hokey Ass Message Board' started by w2w, Apr 16, 2020.
  1. w2w
    w2w
    from East Coast
    so I’m converting my ‘50 deluxe to 12v. But I’ve seen people do it different ways. Somebody only swapped the gen. out, while some guy re-wired and added a bulb that would light if the alt was charging.
    So far I’ve purchased an alt., 12v starter solenoid, 12v coil, some wire and connectors and lights of course.
    Not sure what all needs done or what’s just extra.
  2. oldiron 440
    oldiron 440
    I'd be tempted to replace all the seventy year old wiring, rewiring the car completely.
  3. buster6972
    buster6972
    from Florida
    Vintage auto garage has a great package. Their voltage reducer is really straight forward.
  4. Chgo Sox Fan
    Chgo Sox Fan
    Check out Chevy Talk 1949-1952 under the sticker post section. There is a great step by step guide for conversion. Also you tube “Eric’s Project”. Eric has a 51 Chevy that he shows exactly what he did (bulbs,light, etc.) to convert his daily driver to 12v. I’ll be converting my 51 deluxe with in the next couple of months. Good luck.
  5. w2w
    w2w
    from East Coast
    How do I get to the sticker post section?
  6. squirrel
  7. w2w
    w2w
    from East Coast
    Got her wired but now she doesn’t wanna fire. Read somewhere that the wires to the coil get swapped, neg-pos vice versa
  8. brading
    brading
    Ya now you are running a negative earth you will need to sway the pos and neg leads over on the coil for a start though I think you may have other problems why it is not firing up.
  9. w2w
    w2w
    from East Coast
    Problems such as? Ran fine prior to this. I’m gonna check spark tonight but otherwise can’t think of a reason she won’t fire.
  10. brading
    brading
    When I have seen coils wired up in reverse the engine has still started but not run right. Did make me wonder if you are getting power to the coil. Hopefully I am wrong and changing the leads over cures the problem.
  11. MO54Frank
    MO54Frank
    Your Chevy was originally 6v Negative ground, right? And you converted to 12v Negative ground. No need to swap the coil wires...
    JUSTIN PERSINGER and FortyNiner like this.
  12. w2w
    w2w
    from East Coast
    No, 6v positive ground.
    Currently my coil is + to starter solenoid, - to distributor.
    I could run a wire straight to the battery Incase of an improper power issue
  13. Did you change out your 6v condenser with a 12v?
  14. w2w
    w2w
    from East Coast
    No. It wasn’t a listed piece to swap. At least not on guided I red
  15. These cars were originally negative ground.
    MO54Frank likes this.
  16. w2w
    w2w
    from East Coast
    No clue then. When I got mine, the + was grounded to the engine block and she ran fine.
  17. I'm getting in late on this but I'm ***uming you're running the inline six?
  18. w2w
    w2w
    from East Coast
    Ya sorry. Straight 6, 3 on the tree. 1950 Chevy deluxe. All original.
    I swapped the battery, coil, alt, starter solenoid and bulbs. Wire from the starter to the + of the coil, wire from the distributor to the - of the coil. Byp***ed the thinner wire from the generator and tied the 2 power wires together from the regulator on the firewall. Ran the red wire from the DA alt plug to the stud on the alt (along with the bigger power wire that was connected to the distributor), then ran the white DA wire to my starter ****on (top terminal of the 2 available)
  19. KenC
    KenC
    Wire from ignition switch to coil +? Ignition primary resistor? How about a quick and dirty schematic of all your changes.
  20. w2w
    w2w
    from East Coast
  21. w2w
    w2w
    from East Coast
  22. KJSR
    KJSR
    from Utah
    The condenser doesn't care if its a 6v or 12v system.
  23. abonecollector
    abonecollector
    do you have an alternator "DA" plug? (plugs into the back of the alt., with a ring terminal to the "batt" post on the alternator) You will need one to keep current from running the car even after you've turn off the ignition
  24. brading
    brading
    Just to clarify, looking at your drawing does your coil have Positive power going to it even when the ignition is off.
  25. KenC
    KenC
    Asked the same question earlier. Not mentioned as the only wire is from the starter to the coil. Also no igntion resistor, but does have the byp*** wire from the starter, ***uming that that on is on the starter side of the solenoid, not the battery.
  26. w2w
    w2w
    from East Coast
    Yes I have one & it’s connected like you say.
  27. w2w
    w2w
    from East Coast
    The wire goes from the starter solenoid to the + on the coil. I do not have a separate wire coming off the battery for constant power.
    Also no resistor on the ignition.
  28. brading
    brading
    If there is no resistor in the circuit this is how the coil should be wire up. So that the coil only gets power when the ignition is turned on. Looking at your drawing it appears that the coil is powered up all the time. If this is the case then the coil would be burnt out.
      84.2 KB
  29. w2w
    w2w
    from East Coast
    So having the coil wired hot through the starter solenoid leaves power going to it constantly?
