12v conversion?
Discussion in 'The Hokey Ass Message Board' started by elwood blues, Jun 3, 2008.
  1. elwood blues
    elwood blues
    In terms of the ignition what needs to be done to the points condenser ect? The car in question is a 1952 Plymouth with a flathead 6 the person before me did some sort of *******ized 12v deal and I cant seem to get spark.
  2. Fenders
    Fenders
    Points and condenser should be OK as is, you will have to add a resistor in series with the coil (or use a 12V coil with built in resistor). Some 12V cars shorted the resistor on start to give a hotter spark. Are you getting juice to the coil? If so then when you ground and unground the other side of the coil, you should get a spark.
