Technical 12v generator charge light on with key off
Discussion in 'Traditional Hot Rods' started by Edd, Apr 1, 2022.
  1. Edd
    Edd
    Been a long time since I worked on a car with a 12v "generator". The car arrived with dead 12v battery, charged it and re-installed it. With the car not running and key out a dim charge light can be seen. What is required to correct the situation?
    Thanks
    European Custom likes this.
  2. Probably a bad regulator with a set of sticky contacts.
  3. Edd
    Edd
    You are probably correct...started working again and charging. Thanks
  4. Mr48chev
    Somewhere in my stash of stuff I have an old manual that shows filing those points with a point file when they stick. I remember learning to do it in high school auto shop cl*** but could count the times I have actually done it in the past 58 years on one hand.
  5. sunbeam
    sunbeam
    What Steve said the reverse current cut out stuck and the generator thinks it's a motor not good.
  6. Open the regulator box, and clean the contacts with some fine emery paper. Then hook it all up again. If it still sticks, but goes out when you give the box a thump with your hand, time for a replacement regulator.
  7. nochop
    nochop
    from norcal
    Tap it with a crescent wrench
    studebaker46 and '28phonebooth like this.
  8. That's too heavy handed... use a screw driver handle. It doesn't leave marks.... kind of the rubber hose of the toolbox!
    427 sleeper, nochop and Wanderlust like this.
