Technical 12v generator field kit
Discussion in 'The Hokey Ass Message Board' started by fordwrencher, Apr 28, 2014.
  1. fordwrencher
    fordwrencher
    Who sells 12v generator field conversion kits?
  2. 68hillbilly
    68hillbilly
    from KENTUCKY
  3. What year, what make?
    Charlie Stephens
  4. fordwrencher
    fordwrencher
    converting 1951 ford generator. Larry
  5. tommy
    tommy
    Fords can be easily and cheaply converted by simply using a used 12 V generator body with the fields already in place. Replace the 6V rotor in the 12V body and use a 56 Ford voltage regulator. I used a generator body from a 64 Ford 6 cyl. Fairlane. Free everybody thinks you need a 1 wire alternator. :D
    I did a tech on converting them way back when. I'm sure it's on the HAMB somewhere if you want to hunt.
  6. fordwrencher
    fordwrencher
    Thanks Tommy. Very helpful
