Technical 12v on both sides of coil but no spark
Discussion in 'The Hokey Ass Message Board' started by wheeldog57, Apr 22, 2024.
  1. wheeldog57
    wheeldog57
    Seems to be my nemesis. . . . . No spark.
    Electrical on cars is like magic to me, I just don't get it.
    Rebuilt 8BA
    Old motor 59AB all wiring the same, it ran but was tired.
    Both sides of ballast resistor have power, Both sides of coil have power
    No spark coming out of coil wire to distributor. Tried known good coil and another one off the shelf, what am I missing?
  2. tb33anda3rd
    tb33anda3rd
    points not making contact [not grounding] or bad condenser?
    wheeldog57 and squirrel like this.
  3. Ebbsspeed
    Ebbsspeed
    With points open (or not making good contact when closed) you'll have the same voltage on both sides of the coil. If the points are closed and making good contact you'll have very close to ZERO volts on the points side of the coil and somewhere around 6-8 volts on the ballast side of the coil.
    wheeldog57 likes this.
  4. Moriarity
    Moriarity
    SUPER MODERATOR
    your test light should flash on the minus side of the coil when cranking. if it does not the points are dirty or not closing
  5. Glenn Thoreson
    Glenn Thoreson
    from SW Wyoming
    Points not closing or badly burned. Points incorrectly gapped on the low point on the distributor cam. Adjust them carefully on the highest point.
  6. wheeldog57
    wheeldog57
    Dudes, thanks for quick replies. I'll check points tomorrow!
  7. RodStRace
    RodStRace
  8. Balljoint
    Balljoint
    Might be a good idea to check the coil wire also, even if it’s new.
  9. wheeldog57
    wheeldog57
    Old news but just remembered this thread. . . . I put a known good distributor in and it lit right off! Bought new points, condenser, rotor, and cap for spares
  10. Moriarity
    Moriarity
    SUPER MODERATOR
    so it was probably just dirty or mis adjusted points in the other one
    427 sleeper likes this.
  11. Ebbsspeed
    Ebbsspeed
    That's certainly taking the long road for what should have been a quick trip.
    427 sleeper, Moriarity and wheeldog57 like this.
