Technical 12V to the turn signal switch
Discussion in 'Traditional Hot Rods' started by BarnFind39, May 14, 2023.
  1. BarnFind39
    BarnFind39
    I tried searching this but didn’t come up with anything. Is it possible to use this Yankee Turnflex 730/6 switch once I convert this car to 12V ? IMG_3075.jpeg IMG_3074.jpeg
  2. Last edited: May 14, 2023
  3. goldmountain
    goldmountain
    Easy once you figure out which wire go where.
  4. BarnFind39
    BarnFind39
    Excellent, thanks for the quick reply! I assumed so since I’ve seen that original switches could be used with 12V but I didn’t want to mess it up. It has the perfect patina to go with the car. The wire for the light bulb needs resoldered to the socket and I know I need to change to a 12V bulb. Thanks again
  5. Doublepumper
    Doublepumper
    from WA-OR, USA
    The contacts inside the 6v units are heavy duty and will work forever on 12v.
    Andy and 2Blue2 like this.
  6. If there is a bulb in it just change it out to 12v of the bulbs too. Other it might just burn out sooner.
  7. BarnFind39
    BarnFind39
    Should be good on the bulb once I solder the wire back on. It has a # 51 which an internet search shows it crosses over to a 1445 in 12V
    Atwater Mike likes this.
