13 inch mopar rims
Discussion in 'The Hokey Ass Message Board' started by Jimv, Dec 29, 2005.
  1. Jimv
    Jimv
    I have 14 inch, mopar 5 bolt rims on the front of my T, the rims where off a dart or a valiant( i think).
    I was wondering if there are any mopar 13 inch rims with the same bolt pattern.I have a set of nice 13" tires i'd like to put on the front.
    jimV
  2. squirrel
    the old dart/valiant has a 4" bolt circle, measure center-center across 2 bolts opposite each other should be a little less than 4".
    Should be some 13" wheels for them kicking around somewhere...probably getting a bit hard to find though.
  3. plmczy
    plmczy
    I think the 13 inch rims would have a metric bolt pattern, I'm not totally positive on that. Maybe someone else would know. later shawn
  4. Tha Driver
    Tha Driver
    from S.E. USA
    The 6 cyl. cars (Valiants, Barracudas, etc.) had 13s on them. Not sure what years but my old '65 Cuda had them. And I put the 340/4-speed/273 geared rearend in it & once did 150MPH - & it wasn't EVEN wound out! Very scary as it started vibrating badly (I think it was the driveshaft or the 13" front wheels). I kicked it up in neutral & coasted for about three miles untill it got back down to 70 MPH.
    ~ Paul
    aka "Tha Driver"
    You talkin' dirty or hep?
  5. chitbox dodge
    chitbox dodge
    from dunlap tn
    they all (meaning a bodies) had 13's with 5 on 4 1/4 bolt patterns til 67 i thought anyways. ralleys were 14" though.
  6. Mutt
    Mutt
    The answer is no... 14 inch wheels were 5 on 4.5 inch bolt circle and 13 inch wheels were 5 on 4 inch bolt circle.
    Not to mention that the center hole is too small...
    There are Ford 13 in with the same 4.5 pattern, but the center hole is too small on them also.
    Mutt
  7. squirrel
    14" wheels were used on 4" bolt circle Darts, we still have the set that came off my wife's 70.
    I agree that in general the early cars had 13s, later ones had 14s. But it also depends on what you ordered, the 66 and 68 factory Dart shop manuals list both sizes, the 71 manual only lists 14s.
  8. 2manybillz
    2manybillz
    I'm sure my '71 Demon had 14" wheels but with the small (4") bolt circle on an 8 3/4 rear. 340 *******s had the same thing. I think, but I could be wrong, Formula S Cudas starting in about '65 came with 14" Goodyears, the ones with the blue stripe, blue ovals or something? Damn I've forgotton a lot in the past 40 years. Anyway I think you can find some 4"bc - 13" wheels to fit.
  9. David C
    David C
    I just checked my 66 dart and it has 4" bolt pattern and has a mix of 13" and 14" rims. I probly have 2 13" that would need to be sandblasted and painted or you can try Halls on Plainfield Pike about 2 miles west of 295. 401-647-3648. They have a bunch of 40's to 70's Mopar stuff.
  10. Jimv
    Jimv
    David C , i might take ya up on that!! I work in ***blerland, right near the woonsocket line, near walnut hill.
    jimV
  11. plmczy
    plmczy
    Well hell, I learn sumthin new everyday. I never knew there was anything that had 13's in the early sixties, mopar that is. later shawn
