History ...
Discussion in 'The Hokey Ass Message Board' started by sgtlethargic, Jan 29, 2024.
  1. ...
  2. 302GMC
    302GMC
    from Idaho
    I worked on a Peugeot once. I think it was a 4 speed - it went forward no matter where you put the lever.
    LOU WELLS and vtx1800 like this.
  3. Rusty O'Toole
    Rusty O'Toole
    Lots of European cars had 4 speed column shift transmissions. I think an American 3 speed column shift will work with a 4 speed but you would have to make up something for shifting into Reverse.
    bchrismer, GordonC and Cosmo49 like this.
  4. sdluck
    sdluck
    My step dad had a hillman 4 on the tree
  5. AVater
    AVater
    Some early Econolines had them.
    LOU WELLS, partssaloon and jimmy six like this.
  6. HOTRODPRIMER
    HOTRODPRIMER
    I had a friend that had a 1968 Chevy van that had a 4 speed column shift. HRP
    ffr1222k likes this.
  7. Cosmo49
    Cosmo49
    This! All you need is a heavier pull-push cable. Place column shift in the neutral gate, pull your R cable, Bob's your uncle!
    bchrismer likes this.
  8. Didn’t one of the bosses here do something similar
  9. dwollam
    dwollam
    EARLY Datsun pickups had 4 speed on the column.
    Dave
    lowrd likes this.
  10. studebakerjoe
    studebakerjoe
    @sgtlethargic The Granadas and the Fairmonts came with a floor shift. I've personally seen both. I have a few of the old srod transmissions that I pulled out of them.
    sgtlethargic likes this.
  11. Glenn Thoreson
    Glenn Thoreson
    from SW Wyoming
    Chrysler fluid drive transmissions were a 4 speed on the tree. Being semi automatic there were only two lever positions for forward speeds and one for reverse. One position for 1st and second and one for 3rd and 4th. The forward speeds were shifted by simply lifting your foot off the throttle. For city driving, you didn't need to use the clutch. You just leave the lever in the high speed position. The ****** would downshift into 3rd when you stopped and the fluid coupling allowed it to idle in gear. Taking off from a traffic light was a bit slow but it worked just fine.
  12. Dick Stevens
    Dick Stevens
    I had a Borg Ward that had 4 on the tree
  13. Actually relatively traditional. Add a lever just under the front seat for reverse. Then use all four positions of the three speed shifter for forward gears. When four speeds first started gaining popularity guys were doing that with three speed floor shifters to not have to buy yet another shifter therefore keeping swap cost down
    Cosmo49 likes this.
  14. Rocky
    Rocky
    Classified Editor
    My dad bought a new '64 ranchero with a 260, V/8 4 speed. It was a Dagenhiem trans but was a floor shift.
  15. bushwacker 57
    bushwacker 57
    1965 i worked at a Ford Dealer they had a new 1964 Econoline Van 4 on the tree. I drove it.
    partssaloon and Cosmo49 like this.
  16. Beanscoot
    Beanscoot
    I believe the Econolines were only offered with the four speed column shift for one or two years, and only with the six and very weak Dog and ham transmission.
    I put a toploader in my Fairlane with four speeds on the column and reverse controlled by an overdrive cable control in the stock OD location. I put a slightly larger wire in the control to give it a bit more strength.
  17. Everyone at the Pin*o site told me that a 2.0 wouldn't pull in O/D (T5) unless warmed up quite a bit. Be interesting to see if the Kent pulls. I don't think I've ever seen a side shift RTS or SROD.
  18. 1962 econoline had one i believe, but no o/d
  19. Automotive Stud
    Automotive Stud
    What about just using a borg warner 3 speed with electric overdrive? They were commonly available for all the major cars in the 50's-60's. Shifts like a 3 speed but overdrive is electric.
  20. early 60s had them until they were banned at some point in the 60s. they freewheel below 20mph
  21. 57JoeFoMoPar
    57JoeFoMoPar
    @Jeff Norwell , Didn't you do something like this? I vaguely remember some sort of 4 speed column shift with a pull lever for either Reverse or OD?
    Jeff Norwell and The_Cat_Of_Ages like this.
  22. Moriarity
    Moriarity
    SUPER MODERATOR
    this pic was posted on another thread last week, a 55 chev column shift modified to run a 4 speed, in NZ that is why the column is on the other side, but the concept is the same, some machining and adding another shift arm
  23. okiedokie
    okiedokie
    from Ok
    Bret Chrismer put a four speed in his 40 Ford using the column shifter and the original choke lever to engage reverse. Wish I could remember his HAMB name.
  24. RodStRace
    RodStRace
    I would like to see what's involved with a 4 on the tree like Moriarity posted, but if I were to do it for my own stuff, I'd probably go the other way to simplify and as an anti-theft device. Have the forward gears on the column and a separate floor or dash cable for reverse. Engage both and it won't move. A lot of people can't drive stick, add in this to thwart even more.
    GuyW likes this.
  25. winduptoy
    winduptoy
    @bchrismer
    The GM coaches had 4 speed column shifts in the late '40's and early 50's ....no floor shifter to trip over getting into the drivers seat
  26. Me either. My thinking was if the Lima had the T5 in a production car, why couldn't a slightly smaller version be ok, but I never did find out myself (I will in the future with the Hillmans). The Ford spd O/D trans is easier to find and sometimes cheaper, unless you have the newer trans already.
  27. Let's get REAL complicated. Can/ has anyone converted a top loader [T5] to a column shift?
    Ben
  28. Jeff34
    Jeff34
    That's what I'm doing. '51 Merc with BW 3 speed OD trans. Not sure how well it's going to work yet, but I'm optimistic.
    Hillbilly Werewolf likes this.
  29. Jeff Norwell
    Jeff Norwell
    MODERATOR
    Yes sir!.. works great!.....
    Cosmo49 likes this.
  30. Kerrynzl
    Kerrynzl
    A lot of them had the Dagenham transmissions [AKA English Zephyr]
    The English MK3 Zephyr had a 4 speed column shift [but the lever was on the LH side of the column and the shift arms were on the RH side of the trans for RHD]
    The column shift was quite neat with normal H pattern for 4 forward gears, then you pull the spring loaded lever outwards, then forward and down to select reverse.[the spring loaded lever/detent prevented accidental reverse selection]
    @sgtlethargic Try and import an English Mk3 Zephyr column and "clock" it 180° so the levers and arms are correct for LHD
    Then use a Toploader 3 + 1 transmission [which is basically a conventional side shift trans with 3 - 4 positions reversed on the shift arms and 3 is od]
    The Toploader should be a bolt in for your Ranchero
    The 3 + 1 was available in 77-78
    [Tag numbers are :]
    RUG BP
    RUG CA
    RUG CL
    RUG CD
