Discussion in 'Off Topic Hot Rods & Customs' started by sgtlethargic, Jul 12, 2024.
  1. ...
  2. Is the Check Engine Light on? Have you put an OBDII reader on it to check for any codes? What vehicle/engine is it?
  3. squirrel
    Have you researched if those engines are prone to ignition module failure?
  4. Oooh , I have a 2001 3RZ as well! I'd start by looking at Crank & Cam Position Sensors. Coil packs, ground wires, etc. This sounds like an electric issue more than fuel/air.
    squirrel likes this.
  5. AmishMike
    AmishMike
    Seems to me 335k miles on gas 4 lot of miles pretty worn engine. Why that last plug will not come out, aluminum head? Water in that cylinder? Oil milky? Radiator level still up? Above texas******** ask good questions. Sure would like to get last plug out
  6. Timing chain isn't likely. If it were a V6 with the timing belt, yes, but the 3RZ's all have chains and are not prone to those issues.
    Have you tested all of the fuses & relays?
    With the cam & crank sensors, either test them or replace them to rule them out. They're not very expensive and they're simple to get to. MAF Sensor, IAC, TPS...all of these send signals to the ECM that could possibly lead to this no start.
    Could be an ECM, bad wire in the harness, etc. I'm just spit balling here, as I'm lucky to not have had any issues with my 245k miles 3RZ Tacoma over the last 13yrs. It has been the best vehicle I've ever had, and I have vowed to never sell it.
  7. oldiron 440
    oldiron 440
    I like carburetors, you guys are giving me a headache…
  8. squirrel
    If the engine is not getting fuel, but it has spark and compression, it should run with starting fluid. But if it's flooded, or had been flooded and the plugs are fouled (which you can't always tell by looking at them), then starting fluid won't make it run.
    Usually having 3 cylinders with adequate compression will let a 4 cyl engine run.
    The compression numbers don't indicate a blown head gasket, but a blown head gasket can do interesting things.
    Ignition...fuel...it's all controlled by a computer that relies on proper signals from sensors.
    firstinsteele likes this.
  9. JohnLewis
    JohnLewis
    Heres some potential causes / fixes.
  10. 1. Does spraying starting fluid eliminate fuel system problems, keeping in mind that it's a complex fuel system?
    It byp***es the fuel system, so it doesn't eliminate the fuel system problems, but will help eliminate sensors/electrical issues.
    2. Does a large compression difference make the engine not start?
    That variance of compression across the cylinders doesn't seem to be enough to cause a no start. It'll still run
    3. Blown head gasket? You'd see a bigger variance across the cylinders in the compression test, or water in the oil/oil in the water, really bad spark plugs, or smoke out the tailpipe. it'll still run.
    4. Any other ideas? If that pick & pull long block is decently priced, I'd jump on it and save it for if and when it's needed. A pullout 3RZ is expensive, a rebuilt 3RZ is even more expensive.
  11. Oneball
    Oneball
    Does the throttle plate move when you turn the key on and try and start it?
    If you plug it in to a reader can you ‘see’ the crank sensor?
  12. RodStRace
    RodStRace
    The light flashing sounds like anti-theft. OE or aftermarket, they would normally interrupt spark and fuel (still crank).
    Compression is high enough in the 3 tested to pop, if sprayed with fuel and has properly timed spark.
    Disconnect the battery, charge it if low, then try again after a while, making sure to actuate any keyless entry or alarm before entering.
    If it still will crank but not even pop and still has a spark, it's either timed wrong (cam/crank=chain, most commonly tensioner) or spark timing is wrong (cam/crank sensor) and the computer is unable to trigger spark at the right time.
    If you can pull codes after this test, they may help.
    ekimneirbo and AmishMike like this.
  13. Oneball
    Oneball
    Basic code reader should register rpm (live data) when it’s turning over on the starter that’ll confirm the crank sensor is working.
    RodStRace likes this.
  14. JohnLewis
    JohnLewis
    Customer Concern: It will not stay running but it does crank up and it will not idle.
    Average Reported Mileage: 190213
    Tests/Procedures: 1. When the vehicle is cold and the problem is occurring, open the throttle slightly and check to see if the engine will start and stay running.
    2. Check the idle air control valve opening voltage. The Black/Red wire should read approximately 3.5 to 4.5 volts during crank and slowly go towards 8 volts when warm.
    3. Remove the idle air control valve and monitor the opening angle of the rotary valve when the key is turned on and off. The valve should move.
    Tech Tips: There is a bimetal element built into the idle air control valve that forces high idle when cold. The valve can work perfectly fine by electrical control but not operate mechanically. This will cause a start and stall situation when cold.
    Saw this, If you haven't checked the Idle Air Control Valve yet.
  15. JohnLewis
    JohnLewis
    Customer Concern: The engine starts and then dies after a few seconds of running. It seems to have injector pulse and spark when it dies.
    Average Reported Mileage: 156637
    Tests/Procedures: 1. Eliminate the vehicle's fuel supply and then run the engine on external fuel to see if it will stay running. If the engine stays running, check to see if they are clicking when running it on external fuel. Check the injector on time. Normal idle on time is close to 3.0 M.S.
    2. If there is no injector pulse, monitor the IGF signal from the ignition coils to the Engine Control Module (ECM) to see if it is steady signal. If the signal is cutting out, disconnect one coil at a time to see if the pattern changes. One faulty coil can affect the signal from all the coils.
    3. Check the crankshaft position sensor to see if it has a good pattern. It should produce 3 volts peak to peak on a lab scope.
    And this one for the crank sensor.
  16. Oneball
    Oneball
    Is there a schrader valve on the fuel feed so you can just see if you’ve got fuel by pressing it, put a cloth over it so you don’t get it in the face.
  17. Rodney Dangercar
    Rodney Dangercar
    Something you might consider is looking up "miniVCI" on ebay. I got one of these cables for our 2GR Toy and it's saved my bacon a couple of times when the check engine light came on. You need a laptop or Windows tablet to run the software but it is the real deal when it comes to interfacing with the computer system in the vehicle. The cable is around $25 but there's a couple of things to look out for when installing it.
    Rather than posting the info here (Ryan may not want it) just look up forums where people are using the miniVCI cable to read and alter the computer in your Toyota. Look up "Techstream" on Youtube for more info. I have the drivers on hand for the v1.4 cable and they've been extracted so there are no nasty surprises hidden like there were in the downloaded drivers.
    sgtlethargic likes this.
  18. Headache? Easy remedy
    Ben.
  19. RodStRace
    RodStRace
    Common 3 wire sensor. Numbers are generic, not exact.
    One wire is 5 volt reference. These are often ganged, so 2 or more sensors share this circuit. This allows diagnosing the circuit. 1 bad signal? Probably not reference. These 2? Could be the reference.
    The next wire is signal return. As said, 0 volts to 5 volts. In almost all cases, they will only use most of this range, again for diagnosing the circuit.
    0-.5 volts is not a valid return voltage. This shows the circuit is shorted to ground or open.
    4.8-5 volts is not a valid return voltage. It shows the signal circuit or the sensor is shorted to the reference.
    .5 to 4.8 is a valid return and will tell the computer what the sensor is 'seeing'. Even this is usually outside normal range so abnormalities are 'seen'. Think about extremes for the outside (Ambient) air temperature. Anything from the Arctic to Death Valley. Add a bit at each end to cover any unexpected extreme.
    Third wire is ground. Since the voltage is low and every bit of voltage for the whole car returns through ground, there is a bunch of noise and it's easily possible a bit of corrosion will change the signal. So they have dedicated grounds back to the computer. These are often shared with many sensors and are not usually used like the reference to diagnose.
  20. 05snopro440
    05snopro440
    A few years ago we were on vacation, pulling a big hill coming out of one city late in the day with my wife's 4-cylinder modern SUV. Suddenly the check engine light started flashing and it was instantly down on power. It was running terrible. We ended up limping it back to the city down the hill, and I talked to my buddy who was a master mechanic for the same brand. I got a code scanner and ran the codes, misfire on one cylinder. So I changed the plugs, swapped coils and injectors hole for hole (to see if the misfire would follow), and nothing worked. Got it towed to a dealer, rented a car, and continued our road trip. Turned out that we burnt a piston, and it broke the ring land. It ran terrible, but I was shocked it was that serious. It was a reliable brand of car with low miles.
    Get a borescope, get that last plug out, and check the cylinders and pistons.
    Sharpone likes this.
  21. klleetrucking
    klleetrucking
    from Dalzell,SC
    Please share the resolution to this issue when you find it.
    I'm very, very impressed with the knowledge presented here. You guys have made this computer **** almost understandable, lol.
  22. ClayMart
    ClayMart
    This sounds intriguing. Is the vehicle new enough to have a some kind of a "chipped" or transponder key? Maybe some kind of anti-theft sensor in the ignition switch, or a failed vehicle roll-over sensor?
    Does the "Check Wallet Light" at least light up when the ignition switch is in the on position without cranking?
    Sharpone and SS327 like this.
  23. Rodney Dangercar
    Rodney Dangercar
    You will get live data with the miniVCI cable and the Techstream software. Techstream is the dealership software and what they use to service your vehicle. As RodStRace said, the sensors are the key and the best way to check them is if you can get live data. I went the ELM route and tossed it when I discovered miniVCI.
    With the miniVCI and Techstream you can stream live data, check historical DTCs, current DTCs and clear DTCs for testing. You can also properly bleed the brakes, change reprogrammable options (door locks and such), check TPM battery life and too much more to mention here.
    Regarding the Check Engine light and its function, flashing means STOP NOW and shut down the engine to prevent catastrophic damage (if it already hasn't happened) and steady means there's a problem but you can continue driving to take it in and get it repaired.
    Ignore the flashing light at your own risk.
  24. RodStRace
    RodStRace
    On removing the spark plug, it's just like any steel into aluminum issue. It's probably galling along the threads. Slow and steady, work it a little at a time, with a lot of lube. If it doesn't start getting easier, heat would be the next step. This can be tricky, depending on what's around it, but you do NOT need to heat it a lot. Aluminum expands faster than steel, so a little heat, squirt the lube, heat again, then while it's still hot, try easing it in and out. I had the issue 2 days ago, got lucky, didn't need heat. Expect the head to need some care before installing another plug.
  25. JohnLewis
    JohnLewis
    I'd work on getting that spark plug out. Once its out pull the valve cover and verify your timing marks and check chain tightness. If your marks are aligned I don't think I'd waste the time tearing into the motor much deeper than that.
  26. Oneball
    Oneball
    Just reading your first post again are you sure you’ve got the injectors connected in the right order?
    I know you said you tried ez start but maybe it wasn’t enough.
    JohnLewis likes this.
  27. Los_Control
    Los_Control
    from TX
    I will toss in my 2 cents, I think @Texas******** may have nailed it in his 2nd post with crank & cam sensors.
    I have a different vehicle that uses crank & cam sensors. If the cam sensor goes bad, it will still run .... kinda just does fine tuning.
    If the crank sensor goes bad, it will not run at all.
    You will still get spark from the coil but no signal from the crank sensor to the computer to run.
    The way you describe it lost power then died .... tried to start a few times now nothing .... could easily be a dying sensor that is dead now.
    The simple fact the car has 335K miles on it and original sensors ... you kinda said no work has been done in the past for repairs, just good maintenance.
    Point is, crank sensors go bad and leave you sitting on the side of the road .... I know this.
    When mine went bad at 187K, I replaced the coil, wires, plugs, sensors and just consider it as maintenance.
    You had wet plugs so you are getting fuel, you have spark .... crank sensor is timing.
    It replaces a distributor.
    I would not hesitate to just replace them now .... may not fix your issue, chance it will.
    If it turns out to be something else, you still have original crank sensor in ..... just a matter of time before it fails and you are facing same symptoms again ....
    My 1991 Chevrolet truck has a ignition control module inside the distributor.
    It went out on me a couple months ago. Dead in the water.
    That sends the signal to the computer to run .... the crank sensor does the same thing .... they go bad.
  28. Los_Control
    Los_Control
    from TX
    I hate to say it .... I would probably be better off to just ignore your post and move on.
    Since I love you as a brother .... I want to help you.
    You have 14 questions above asking for answers ..... tells me you do not have a clue as a mechanic to actually fix the problem .... 1 or 2 questions I get it ..... 14 questions take the car to someone else.
    You will never figure it out and if you want your girls car running and save face ..... you need to be smart and have it properly diagnosed.
    With your 14 questions above, you are obviously not qualified to fix it ..... thats fine.
    To drag a poor girl through your BS when she needs a car .... grow a set and ask a professional ... you will never fix it.
  29. JohnLewis
    JohnLewis
    Honestly it's obviously hard to diagnose something over a computer. Like the above comment. I've got access to alldata and identifix. I can get info and put it here on the engine control system if you want it. I just need a year make and model, vin is the best. Going off a engine description I'm just taking a guess. Vehicles and their computer control systems are different between models and options. But saying you tested something doesn't mean it was done right. Without the right tooling to actually access a vehicles system or properly test and the knowledge you're just creating a circle for yourself.
  30. JohnLewis
    JohnLewis
    I'd run through the Diag before I just took it apart. The scanner you're waiting on should help a bit. Swapping parts for a known good part is kinda up in the air. If the ECM saves the data from the old part and runs off those values until it has enough run time to re-learn then it's going to do the same thing.
    I've never ran into a situation where the Evap system caused a no starting condition. Just considering its a non primary system.
    My own opinion if the access is there I'd do the spark plug with the head on. I wouldn't take the head off unless I had to.
    Test the Fuel System. Test the ECM. Your Ignition and Fuel Timing is going to be ran off that.
    Compression is still over the minimum value for the motor, I wouldn't worry about rebuilding a 300+ thousand mile motor.
    klleetrucking and sgtlethargic like this.
