15 inch wheel shells
Discussion in 'The Hokey Ass Message Board' started by brucer, Sep 26, 2010.
  1. brucer
    brucer
    from western ky
    anyone know a place where i can buy 15 inch shells in 8inch and 4inch widths.. the 8inch wide shells are no problem, cant locate any 4inch wide shells..
  2. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Don't have an answer but if your trying to make your own wheels that you have centers for just try the boneyards and cut the centers out of a wheel with the ID you need. Just an idea is all. Missed the part about 4" being hard to find. Ya VW shells or wheels use to be easy to come by.
  3. F&J
    F&J
  4. NONHOG
    NONHOG
    Might look at Volvo Amazon (122) they are 4" and the wagons are 4.5"
    They have a Ford bolt pattern but that won't matter if all you want is hoops.
  5. 26 roadster
    26 roadster
    Problem is locating shells with an I.D. close to what you want, been looking for a long time. I really don't want to "turn" the "character" out of the centers.
  6. das858
    das858
    1995-1998 mustang space saver spare,15" diameter, 4" wide with 4.5" x5 lug bolt pattern.
  7. oldtin
    oldtin
    Cut the centers out of some steel space saver spares. I used some gm 16"ers to replace the rusted out rims of some wide 5 wheels I had. Do you have a dimension for the centers your using? I may have some 15"s around that I can check the sizes on.
  8. Bearing Burner
    Bearing Burner
    from W. MA
    When I was looking for 4" wide rims several years ago I was told by a wheel manufacturer that the only supplier of 4" rims stopped making them. I used GM space saver rims.
