15" tires
Discussion in 'The Hokey Ass Message Board' started by bonestheripper, Feb 13, 2009.
  1. bonestheripper
    bonestheripper
    what's up fellas. anyone know what size tires are the tallest for a 15" rim? i would prefer radial but will settle for bias ply.
  2. Jalopy Joker
    Jalopy Joker
    Did you check with Coker, other tire sellers?
  3. H3O
    H3O
    how wide is your wheel? that depends too. i've seen 33 but that was a commercial tire for an 8-10in rim i think.
  4. AnimalAin
    AnimalAin
    For an ordinarily wide rim (7-8 inches) a P265/75R15 is pretty good. Not as wide as the late, lamented P285/70R15, but within a whisker of the same 30-31 inch height. I recently put some Hankooks on the back of my '41 pickup, and they look and work fine.
    If you are running a little narrower wheel, consider a P235/75R15; about 29 tall.
  5. Phil1934
    Phil1934
    Bfg ta ko 33x9.5
  6. 265/75/15 Approx 30 3/4" tall. My tire vendor says he can get some in a street tread, but didn't tell me the brand.
  7. Phil1934
    Phil1934
    BFG Long Trail T/A Tour
  8. 201
    201
    Talked to Coker about three weeks ago and the 285/70R15's are avalible again. There not made by BFG,but by I think Michelin or whoever bought BFG. Tread patern is the same as the T/A's
  9. bonestheripper
    bonestheripper
    rim width is 4.375". i'm currently running 225/70R15 BFG's but the crown is a bit too wide for my taste and not tall enough.
  10. Royalshifter
    Royalshifter
    Moderator
    8.20 bias Firestone.
  11. H3O
    H3O
    might want to check with diamond back. they have tall and skinny tires but i think they are for 16s tho. they make 215/80 and 215/85. they are radials. but i think they are only whitewalls.
  12. Jalopy Joker
    Jalopy Joker
    So, have you checked with Coker, Diamond Back, etc?
  13. bonestheripper
    bonestheripper
    i checked with coker tires.. they suggested 7.00-15. if i dont find radials that are equivalent to that, i'll try em on for size and let you all know how they fit.
