15 X 4 rims...what tires are you running?
Discussion in 'The Hokey Ass Message Board' started by Krash Vegas, Jun 22, 2010.
  1. Krash Vegas
    Krash Vegas
    Got a set of 15 x 4 slots for my 55 and it's been a while since I had to buy street tires for skinnies.
    What are you guys using?
    I just bought a pair of Hurst Pie Crust "Cheaters" for the rear, the 15 x 10 x 30's.
    Need something that will work with these and look right.
  2. 155-165 VW type tires. Kleber, Vredestein, Coker sells them in Michelin. We scooped up a bunch a few years back in Denver. Any large metro should have a store selling the tires. My problem is I only have ONE 15 early Ford steelie at teh moment! 16s until I find a mate.
  3. Muttley
    Muttley
    I'm running Pro-Trac 5.60 x 15's on the front of my Comet.
  4. indyjps
    indyjps
  5. Muttley, I always forget about the ProTracs!
  6. PRIMERDAVE
    PRIMERDAVE
    would those work on 15 X 3 1/2 wheel also ??
  7. cruisin30
    cruisin30
    from Katy, TX
    165/80/15's on my front now.
  8. CONNMAN
    CONNMAN
    from Lampe,Mo.
    On my Old '55 ,,with 15 x 4 Ansen Sprints ,,i had Michlen 5;60's ,,26 inches tall ,,150 mph speed rated ,,to clear the fender well hedders ,,,cheap from the tire distributor here at $67 each ,,mounted n balanced
  9. CONNMAN
    CONNMAN
    from Lampe,Mo.
    >>>Oh sorry ,,the new tire size is 165 x 15 ,,,70 series ,,
  10. wild willey
    wild willey
    I'm wit MUTTLEY!
  11. 1934coupe
    1934coupe
    I have 165SR 15 Pirelli Cinteratos on my 57 w/4in American TQs and we ran this same tire or a Continental VW tire back in th 60s . Always looked *****en on the Willys.
  12. 1934coupe
    1934coupe
    Muttley that Comet is pretty cool. I was looking for a look on the 57 and I have Pro-Trac 385 x 60 x 15 on the back
    Pat
  13. CONNMAN
    CONNMAN
    from Lampe,Mo.
    YES 1934 coupe; back in the late '60's on my C/Gas 396 Big Block Chevy powered '54 Ford P/Up ,i ran 5;60 x 15 VW Perrellis ,,
  14. Solospeedshop
    Solospeedshop
    560 15 Blackwall firestones from Coker Nice Bias Ply Look!
  15. Muttley
    Muttley
    The Coker site says the recommended rim width is from 4 to 5 1/2 inches.
  16. senior fried
    senior fried
    I have used quite a few kinds of skinnies and I like the Moroso DS 2's the best , Mickey Thompson sportsmans are also good . Not sure what kind of driving you are going to be doing.
  17. Skirv
    Skirv
    No close-up shots but I used 5.00X15 B.F. Goodrich Silvertowns from Coker on the front of this Anglia. They are nice looking tires if you don't want a piecrust edge. PieCrust cheaters from Radir on the rear, 15X10, for comparison.
  18. teddisnoke
    teddisnoke
    from So Cal
    Be wary of mixing up radials and bias ply tires. They WILL follow the road, and catch you by surprise on some occasions. One other item of note, is to check the weight ratings on some of those skinnier tires, like the Klebers. They are under-rated weight-wise for a heavier car. Even when you get into Firestone fronts, when you start dipping below say the 6.40-15's, you need to pay attention to the weight ratings in my opinion if you plan on putting miles on. On our altered wheelbase cars, we usually stick around 6.40-15's and 6.70-15s, the latter being for the full size cars, like a Polara, or such.
    Dale
  19. AnimalAin
    AnimalAin
    I run 165R-15 on 3.5 or 5 inch rims. Easily available, not too expensive, durable. Measure about 25 inches tall. Probably not optimal for autocross.
  20. flameboyzero
    flameboyzero
    6.70x 15 on my car[​IMG]
  21. Royalshifter
    Royalshifter
    Moderator
    BF Goodrich 500x15 blackwall....just ask KiwiKev.
  22. flameboyzero
    flameboyzero
    and those are 15x3.5 fenton gyros
