Hot Rods 16 and 18 divco wheel redo
Discussion in 'The Hokey Ass Message Board' started by etwheels, Sep 11, 2024.
Tags:
  1. etwheels
    etwheels
    from ca.
    Hello all:
    looking at redoing the 18" wheel that All American Mfg did.. That wheel was a Divco style wheel and i would like to do a 16" front that matched. Looking to get a feel for the interest in this wheel, let me know.
    also looking for 1 wheel from them, borrow or buy.
    scott
    Tetanus, Randysbelvedere, Stu and 2 others like this.
  2. silent rick
    silent rick
    depends on price
  3. douglasb
    douglasb
    There is probably a good market for then as people are always looking for them real or repo
    G_Don likes this.
  4. Anderson
    Anderson
    To reduce the features of a Divco from 18” to 16” but keep the use of a stock sized hubcap, everything gets so small that it’s almost not a match to the rear wheel anymore.
  5. This would be great, definitely interested in a set if they are priced well.
    Attached is a photo of 16" 1937-38 Chev wheel, same window count as High Clearance "DIVCO" wheel, If you match the window shape, proportions can work in 16"
  6. krylon32
    krylon32
    from Nebraska
    The last run of 18 inch steelies Steadfast made were $395 each and Wheels Vintiques were just a tick over $500 each. There's dam sure a market for 18's and everyone needs 16 inch fronts to match. I've got 18's on the back of my Henry Highboy on Steadfast steelies and 18's on the back of my project roadster on 18 inch 32 wires widened by Bruce's Rod Shop. With shipping widening cost about $1200. Definitely a market.
  7. wheeltramp brian
    wheeltramp brian
    I'd be interested.
  8. 562roadster
    562roadster
  9. Happydaze
    Happydaze
    Yep, do it!
    Chris
  10. brady1929
    brady1929
    I like the idea. Depends on cost.
  11. etwheels
    etwheels
    from ca.
    The wheel would be lighter than a steel wheel for better ride, less un-sprung weight, and the target price 325 to 350 ea it will depend on the final weight.
    As for the cap , plan is to use 2 different size caps to keep the proportions correct.
    IronFord, Gasser 57, RMR&C and 2 others like this.
  12. alchemy
    alchemy
    Definitely should fit the original Ford cap. Bonus points if the lug area looks like a Ford with the cap off (ins and outs).
    562roadster likes this.
  13. Malcolm
    Malcolm
    from Nebraska
    I had a pair of the American Mfg. aluminum 'Divco' wheels on my roadster for a bit. The were HEAVY. I'm looking forward to seeing how light you can get your versions.
    Outback, teach'm and Dedsoto like this.
  14. Happydaze
    Happydaze
    The 18's in steel are really heavy though! Considerably more m*** in 18" than 16", which seems crazy for a measly extra 2" , but that's pi for ya!
    Chris
    RICH B, Just Gary and Malcolm like this.
  15. Stu
    Stu
    Sign me up!
  16. Anderson
    Anderson
    that sounds cool, but then how many options will you have for caps? And how much will the custom made caps cost? Will they be stainless like the other reproductions available or aluminum? Will a factory cap fit the wheels at all? And if not then will you have to buy a full set of custom caps so that they do all match?
    Not trying to beat you up but these are all concerns I’ve recently been a party to with a very similar wheel quest.
    Outback, RAK, teach'm and 2 others like this.
  17. DaveyJonez
    DaveyJonez
    from Houston
  18. That price I will be down for a set for sure, likely just 18" will hold judgement on 16" until I see finished design
    Will the wheels be blank so they can be drilled for different stud patterns? The ability to run stock hubcaps is a big plus.
  19. Not sure if this helps, from the Tyrods coverage by Wheeldog 57. 3C08538A-E2B2-447F-8268-5991BA7F4F4F.jpeg 985C9387-E2B6-4E91-BDB6-939B9A993057.jpeg
  20. etwheels
    etwheels
    from ca.
    Here is the plan 2 sizes of wheels and 2 caps, so the wheel stays in proportion. Looking at plain cap , ie. no lettering , initial sizes 8.125" and 7.125" , but that may change. Caps will be extra.
    wheel sizes 18 x 5.5 or 6 and 16 x 5, this will depend on the available tires.
  21. alchemy
    alchemy
    I’m pretty sure that if the original caps don’t fit, your market will be smaller.
    My opinion: don’t worry about smaller caps on the smaller wheels.
    chrisp, DaveyJonez, teach'm and 3 others like this.
  22. 38Chevy454
    38Chevy454
    Just my opinion, I would go 18x6 and 16x4.5. People want skinny fronts and wider rears.
  23. Nacifan
    Nacifan
    I'm in for a set of 18 x 6 and 16 x 5. Would that be 5 on 4-1/2" bolt pattern Sir ??
  24. 562roadster
    562roadster
    The closer to the original size the better, thats what made the American Mfg desirable. 18x5.5”, for original hubcaps would be my vote
    Stovebolt and Jimmy B like this.
  25. lilCowboy
    lilCowboy
    I'll take two 18"s (and possibly the 16"s depending on the finished product)
    Outback likes this.
  26. Anderson
    Anderson
    What tire do you recommend for your 18x6? The 7.00-18 Firestone from Coker has a recommended rim width of about 4”.
  27. PotvinV8
    PotvinV8
    If weight is a concern, do them in Mag like Halibrand did. :cool:
  28. etwheels
    etwheels
    from ca.
    OK, as for the Mag comment, that is the .5% crowd, as the cost becomes to expensive. We do a small 13" x 10 wheel for a can-am car in lots of 12 ea. , it is a 2 piece with a bolted on inner half the finished face was $1500.00 ea last time i ran them about 10 years ago. Small run , poor yeilds, ect, as a point of reference.
    Next we plan to use a Beanie style cap for the rear, so std cap would also work. But as for the 16" wheel, it may need a smaller version to keep the proportions correct for modern street rods. the initial plan is to make a standard smaller cap fit , and make a beanie to fit.
    Tim, Stu and 2devilles like this.
  29. littlemann
    littlemann
    from colorado
    Checking to see if this ever took off....??.... I'd be interested in an 18" set and possibly a set of 16" for the front.
