Hot Rods 16 and 18 divco wheel redo
Discussion in 'The Hokey Ass Message Board' started by etwheels, Sep 11, 2024.
Tags:
  1. @etwheels I tried to talk to you at GNRS last year about kidney bean style wheels in 5 on 5 1/2 for my coupe. You handed me a sticker and said you were too busy to talk. How about now?
  2. banjorear
    banjorear
    I'd be in for 16" fronts at 4" wide and a 18" rear at 5-7" wide.
  3. RockyMtnWay
    RockyMtnWay
    What he said!
    That’s what I’d go for as well, but I’d prefer them at 5 on 4.5” bp so I’d don’t have to change anything.
  4. etwheels
    etwheels
    from ca.
    i am working on the 3d for the wheels now, borrowed an 18 from a customer, and have the derby cap and a 40 cap.
    hope to have designs done before Christmas. initial lug patterns will be 4.5 and 5.5 dual drill. Also looking at careful design so it can be widened or narrowed with a spun rim half. Undecided if they will all be black or just in prime ready for you to paint the color and sheen desired.
  5. alchemy
    alchemy
    Double bolt pattern kills it for me. Might want to use them without caps sometimes and wouldn’t want the extra holes screaming “repro” at me.
  6. silent rick
    silent rick
    why not drill to order, any bolt pattern, even 6 pin knockoffs
  7. 421-6Speed
    421-6Speed
    I'm with 562roadster...
    Outback likes this.
  8. 421-6Speed
    421-6Speed
    Agreed...
  9. Malcolm
    Malcolm
    from Nebraska
    I had a similar experience at the GNRS quite a few years ago.
  10. Drill to purchasers desired pattern, dual pattern wrecks the look if you don't want to run caps.
  11. littlemann
    littlemann
    from colorado
    Hey, why dual bolt pattern?
    I would love to see these drill to order.
    gimpyshotrods and Outback like this.
  12. Anderson
    Anderson
    The centers are likely to look like this anyway…while dual bolt patterns would look worse, I don’t think I’d want to run this without a hubcap in any case.
    Tim, Outback and Jimmy B like this.
  13. alchemy
    alchemy
    If I bought a wheel like Anderson showed, I’d have my buddy write a program to carve the innies and outies around the lugs so it looks more like Kelsey Hayes made it. Not sure why the manufacturer can’t do that.
  14. littlemann
    littlemann
    from colorado
    I guess you could have someone machine out the center section of a normal rim and secure that in place to hide the dual bolt pattern.........
  15. littlemann
    littlemann
    from colorado
    Eagerly awaiting an update.....
    Outback and Just Gary like this.
  16. Phat Ralph
    Phat Ralph
    Interested in a set of 16 & 18's. Any update?
  17. 1lucky1
    1lucky1
    from Morgan NJ
    I have 18 inch repos on the back than had Mike Curtis make me some 15 inch for the front because I wanted a real small tire,Using 41 hubcaps that got painted to make center smaller 20211205_151808.jpg
    El Hueso, rod1, A Boner and 7 others like this.
  18. curbspeed
    curbspeed
    I would suggest a 16 x 3.5 front wheels or a 4". I like my fronts to look like hotrod wheels instead of big wide truck rims.
    littlemann likes this.
  19. justabeater37
    justabeater37
    etwheels
    Member, Male, from ca.
    etwheels was last seen: Nov 12, 2024
    Been awhile since he's been on here. Project a no go? Too busy to post? Who knows.
  20. IronFord
    IronFord
    from NoDak
    I'd be interested in a set of 18s, but only if they are single bolt pattern. Not everyone wants to run caps all the time.
    gimpyshotrods likes this.
  21. Randysbelvedere
    Randysbelvedere
    from Toronto
    Anyone have an update from ETWheels? I hope this is still in the works.
  22. uncle buck
    uncle buck
    ET Wheels was Last here on November 12 , 2024
  23. A Boner
    A Boner
    Like the 41 dog dish caps with the outer part painted. Fantastic Sedan!
  24. Anderson
    Anderson
    This car is debuting at the roadster show this weekend…it’s wearing 18” and 17” “divcos” machined by Mike Curtis. The rears are more “deep dish” than originals or the aftermarket ones to help push the tire away from the body.
    1lucky1, Troublemaker427, Tim and 5 others like this.
  25. IronFord
    IronFord
    from NoDak
  26. uncle buck
    uncle buck
    Nothing has changed here other than it sounds like Mike Curtis is your best hope
  27. littlemann
    littlemann
    from colorado
    I emailed ET Mags a couple of weeks ago and they replied with:
    Hate to keep pestering them with what/if/when/etc....BUT... I'm hopeful they come through and start to produce ASAP!
    Steve009 likes this.
  28. gimpyshotrods
    gimpyshotrods
    I won't be able to drive for about a month, but when I can, I'll head over there and pester them in person.
  29. littlemann
    littlemann
    from colorado
    Outback likes this.
  30. gimpyshotrods
    gimpyshotrods
    Will do!
    I will certainly be in that area the first week of June, but may be there sooner, depending on getting back to walking.
